02-06-2016, 06:44 PM | #1 |
67-72 fleetside rear bumper on our trucks.
Ive seen a few pictures of this and was hoping someone could post more pictures and possible the install and what they had to do to make brackets for it. I am really liking the way these look.
Thanks in advance guys! Aaron
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
02-06-2016, 08:10 PM | #2 |
Re: 67-72 fleetside rear bumper on our trucks.
Just use the 67-72 fleetside brackets that go with the bumper and it will bolt right up.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
02-06-2016, 08:24 PM | #3 |
I just did this and what MisterC said is spot on.
See my post earlier today
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-06-2016, 08:25 PM | #4 |
Moderator
Fits perfect, and looks like it was made for our trucks. Great mod.
02-07-2016, 01:17 AM | #5 |
Kinda hard when im using a 62 frame. I guess I should have stated that.
02-07-2016, 11:25 AM | #6 |
60-62 frames are 8" wider than 63-72, im not sure how you can do that other than some serious fab. Good luck!
02-07-2016, 11:48 AM | #7 |
I had the 60-62 brackets for a stock bumper. After several bad looking chrome bumpers I swapped over to the 67-72. I cut the bracket to fit. Some flat stock would work just the same. If a welder is not available find something prebent that can cut.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
