72 tilt column b/u light connection
Hi everybody. I have a 72 tilt column in my 65 Suburban, and I want to hook my aftermarket backup lights to the nsw but there are no open terminals on the switch to hook to. Can someone help me with this? Thanks
Re: 72 tilt column b/u light connection
Did you look at a schematic? They are in the FSM.
The Dark Green (75) is the feed from the fuse block and the Light Green (24) is the switched output to the locally grounded lamps.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: Oct 2010
Is that a manual NSS? If so just change it out with an auto switch and be good to go.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
I believe it's an auto nss. I had the column put in about 17 years ago. My backup lights are units I bought at Autozone and are run off of a rocker switch on the dash.
I agree with Tim, the greens are what you use
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
