Old 04-14-2016, 12:29 AM   #1
Smokeem
Throttle cable bracket help
Guys needing your help figuring this out. I ordered this bracket from Summit as they said it was the correct for my edelbrock carb. I go to install it and ran into a problem. I can not get he throttle cable into the bracket. There looks to be no way it's going to fit unless I cut the bracket up. Do I have the wrong bracket? Or does the truck have the wrong throttle cable? Truck is a 72
Smokeem is offline   Reply With Quote
Old 04-14-2016, 12:30 AM   #2
Smokeem
Old 04-14-2016, 12:31 AM   #3
Smokeem
Old 04-14-2016, 09:58 AM   #4
68 P.O.S.
Re: Throttle cable bracket help
I ran into the same problem when I bought mine. I ended up cutting the top of the bracket and trimmed the rubber so it would slide on. I read here on the forum somewherr that the the later trucks have the correct throttle cable for the bracket. I also bought the matching kick down cable bracket and it works just fine.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-14-2016, 10:22 AM   #5
Smokeem
That was what I was thinking I was going to have to do. Just didn't want to cut the bracket and then find out I had the wrong cable. You have any pictures of your installed?
Old 04-15-2016, 02:02 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
Search the parts boards, the factory brackets come up used now and then. Member RogerKoop had some for sale a while back. The factory one has a round hole with a wedge shaped slot cut into the side of it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-15-2016, 02:21 PM   #7
Smokeem
I can't use any bracket but something like I already have. Running an air gap intake with no where to mount a stock style
Old 04-15-2016, 02:22 PM   #8
70STOVEBOLT
Stock bracket mounts on the left rear carb mounting bolt/stud.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-15-2016, 02:35 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The factory bracket will have about a 1/2" slot in the side of it that the rubber grommet on the cable slides into. I'd just cut a slot.
It will look like the top part of this bracket.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-15-2016, 02:46 PM   #10
Smokeem
Ok I had seen one that mounted to the intake and I thought that was how the stock one were. I've already go he mounts and brackets just will have to do some trimming to the one to get it to fit
Old 04-15-2016, 04:54 PM   #11
70STOVEBOLT
This is what the stock bracket looks like. It does not have the provision for kickdown cable, however.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-16-2016, 09:35 AM   #12
GASoline71
GASoline71's Avatar
Yep... The one I showed is an aftermarket bracket made by Holley. I used one on my 1972 GMC cable, but had to modify it to work with my setup.
Gary
