08-09-2016, 04:42 PM | #1 |
20' Daredevil (Ret)
Recommended Clutch Fan?
My OEM fan clutch is showing signs of wear and I plan to replace it before long. It's weeping a bit of fluid near the shaft and the fan has a tiny bit of wobble. Online shopping has turned up several that will fit, but I'm not sure if some are better than others. Any that you like, or any that you would avoid? Right now I'm leaning towards an ACDelco 15-80245 which *may* be an identical replacement. Thanks.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-09-2016, 07:04 PM | #2 |
Re: Recommended Clutch Fan?
I bought this one - not the cheapest but I too wanted ACDelco. Amazon lists it as a direct fit, but it's not cosmetically identical to the old ones. Close though.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-10-2016, 10:03 PM | #3 |
20' Daredevil (Ret)
Yup, they show that as correct for your big-block GMC, and 15-80245 for my SBC.
So you are happy with the way yours works? Engages and disengages when it should? Curious because I have read about some units being too aggressive (for lack of a better word), locking up too early and staying locked for too long, creating power loss and extra noise.
08-11-2016, 01:49 PM | #4 | |
Seems to tighten up an appropriate amount for the heat load.
08-11-2016, 09:21 AM | #5 |
2WD Jimmy
I have a Real AC Delco brand new in the box that you can have for $75 plus shipping. I paid way over $100 bucks when I bought it.
08-11-2016, 09:37 AM | #6 |
20' Daredevil (Ret)
The one I have been looking at claims to be AC Delco. If you don't mind my asking, is there a difference between yours and that one? What's the p/n on yours? Thanks.
08-11-2016, 11:26 AM | #7 |
2WD Jimmy
Hows this? if you cant read it, the number is 22050676 This a Real GM clutch fan, not a chinese knockoff... Dayton Ohio, USA made.
08-11-2016, 03:24 PM | #8 |
I just got mine from GM. Part #19189681
1969 396 Says made in USA on the clutch....
IT IS WHAT IT IS |
08-11-2016, 04:07 PM | #9 |
20' Daredevil (Ret)
Thanks for the feedback, guys, I appreciate it. And thanks for the offer, Tom. That unit may do the trick but it does look different than mine, and the p/n is different. I'm going to do more digging before I commit.
08-11-2016, 04:15 PM | #10 |
2WD Jimmy
Mine is for a smallblock.
08-15-2016, 03:23 PM | #11 |
20' Daredevil (Ret)
Update, and I'll keep it brief. There are three types of thermal fan clutches -- standard duty, heavy duty, and severe duty. Good explanations / illustrations here: http://www.haydenauto.com/featured%2...s/content.aspx
My K20 uses a heavy duty unit but I could not find one. Virtually all are standard duty, and a very few are severe duty. Went to my local NAPA and another customer overheard us and suggested looking up the part for a slightly newer K30. Bingo! NAPA p/n 271303, fan clutch #2747. Made by Four Seasons in Lewisville, Texas. Tom, I have to pass on yours. It is a standard duty and not recommended for my K20.
08-15-2016, 06:22 PM | #12 |
Tom,
Is the Delco clutch fan you have, a thermal or non-thermal? I made a similar post about replacing mine and wonder if the part you have is a direct replacement. Forum members answered suggesting that I get a thermal style for replacement. Thanks Sam |
11-07-2019, 10:44 AM | #13 | |
I'm having trouble finding the actual fan blades themselves to run with this clutch! Any recommendations? |
11-07-2019, 11:15 AM | #14 | |
20' Daredevil (Ret)
11-07-2019, 02:54 PM | #15 | |
Thank you for the info! |
03-31-2023, 10:46 PM | #16 | |
I have a question for you regarding your fan clutch. How did you determine that your K20 required a heavy duty unit, as opposed to the standard duty one? I am looking to install a clutch fan set up in my '72 K20 as well, and all my research so far has pointed me to the Hayden 2705 fan clutch (Standard duty) as being correct for my truck. Did you go with the heavy duty unit because your truck is an A/C truck? Mine has no A/C and manual transmission. I am looking to use the 18 inch Derale 17118 fan as mentioned above, but I am not sure if I should go with the 2705 fan clutch or the Heavy duty 2747 as you are running. I am setting up my truck to haul a 22ft camper trailer on occasion. Thanks for any input!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
04-01-2023, 12:05 AM | #17 | |
20' Daredevil (Ret)
If you haven't already seen it, Hayden's website shows the differences between clutch types. https://www.haydenauto.com/en/produc...-types/thermal
04-06-2023, 12:07 PM | #18 | |
I think a 7 blade fan would be perfect for my truck, but when I did some looking I couldn't find one that specifically fit our trucks. Do you happen to have a part number for your factory original one that I could use to help me search?
08-15-2016, 08:10 PM | #19 |
20' Daredevil (Ret)
Guys, if I may, Tom's Delco above is a standard duty thermal. The above link clearly shows how to make the determination.
08-15-2016, 08:27 PM | #20 |
Thanks for clarifying Mike.....I went to that site to read the differences but it obviously didn't sink into my thick skull
I'm learning..... |
08-17-2016, 03:50 PM | #21 |
20' Daredevil (Ret)
Just to follow-up. I installed the new fan clutch yesterday. With the old one off, I could see it had seeped out a lot more fluid than I had thought. The shaft and the rear of the unit were heavily coated with built-up gunk. On a side note, I had also been unsuccessfully chasing what sounded like an occasional fan belt squeal. It would only happen around 1200-1300 rpm.
Took her out for a test run this morning. Temp gauge stayed at the lower end of normal, which is right where it usually reads. Went up the mountain and it climbed to a bit below halfway, typical for the situation. And I cannot create the 'squealing fan belt' noise. I suspect it was coming from the old fan clutch since it had lost a significant amount of fluid. Everything seems to be working just like it's supposed to.
06-10-2017, 08:00 PM | #22 |
But Found Her 25yrs Later!
Saved for reference.
06-10-2017, 08:42 PM | #23 |
I ordered this Delco one for my 402, but when it arrived it had the Severe Duty style and shape, not like pictured.
06-10-2017, 10:01 PM | #24 |
20' Daredevil (Ret)
Severe Duty *might* be overkill (stay engaged too much, extra roar, use a bit more fuel) or it might be just what that big engine wants. Are you planning to keep it, or return it and get a Heavy Duty unit?
06-13-2017, 12:48 PM | #25 |
It doesn't seem to run too much or make any additional noise, so I kept it and am running it!
