20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Recommended Clutch Fan?
Update, and I'll keep it brief. There are three types of thermal fan clutches -- standard duty, heavy duty, and severe duty. Good explanations / illustrations here: http://www.haydenauto.com/featured%2...s/content.aspx
My K20 uses a heavy duty unit but I could not find one. Virtually all are standard duty, and a very few are severe duty. Went to my local NAPA and another customer overheard us and suggested looking up the part for a slightly newer K30. Bingo! NAPA p/n 271303, fan clutch #2747. Made by Four Seasons in Lewisville, Texas. Tom, I have to pass on yours. It is a standard duty and not recommended for my K20.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Sep 2014
Tom,
Is the Delco clutch fan you have, a thermal or non-thermal? I made a similar post about replacing mine and wonder if the part you have is a direct replacement. Forum members answered suggesting that I get a thermal style for replacement. Thanks Sam |
#3 | |
I'm having trouble finding the actual fan blades themselves to run with this clutch! Any recommendations? |
#4 | |
20' Daredevil (Ret)
#5 | |
Thank you for the info! |
#6 | |
I have a question for you regarding your fan clutch. How did you determine that your K20 required a heavy duty unit, as opposed to the standard duty one? I am looking to install a clutch fan set up in my '72 K20 as well, and all my research so far has pointed me to the Hayden 2705 fan clutch (Standard duty) as being correct for my truck. Did you go with the heavy duty unit because your truck is an A/C truck? Mine has no A/C and manual transmission. I am looking to use the 18 inch Derale 17118 fan as mentioned above, but I am not sure if I should go with the 2705 fan clutch or the Heavy duty 2747 as you are running. I am setting up my truck to haul a 22ft camper trailer on occasion. Thanks for any input!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
#7 | |
20' Daredevil (Ret)
If you haven't already seen it, Hayden's website shows the differences between clutch types. https://www.haydenauto.com/en/produc...-types/thermal
#8 | |
I think a 7 blade fan would be perfect for my truck, but when I did some looking I couldn't find one that specifically fit our trucks. Do you happen to have a part number for your factory original one that I could use to help me search?
#9 | |
20' Daredevil (Ret)
Summit has this one https://www.summitracing.com/parts/oer-k193?rrec=true which looks like the one above. Might be worth a phone call to ask if the blades are evenly spaced (as pictured) or asymmetrical.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-06-2023 at 02:27 PM. |
#10 | |
