08-23-2016, 09:47 PM | #1 |
Timing cover
I have a oil leak in the front while my 216 is running. I suspect the seal and gaskets have gone bad on cover and pan. I'm aware of the timing cover modification for outside bolts. I don't plan on doing that as it requires pulling radiator and other items for front access.
Is it possible to remove timing cover with out pulling out radiator? |
08-24-2016, 02:06 AM | #2 |
Re: Timing cover
I would bet on the front seal behind the balancer. I recently just took apart my 235. There are two bolts under the pan that you have to remove to get the front cover off. A big pain. I think either way the rad gonna have to get moved.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
