Old 08-23-2016, 10:21 PM   #1
1970pelle
1970pelle's Avatar
A little speedo gear help needed please.
With a the changing around on my 86 C20 I have done. I thought I had it figured out when I ordered the new trans. Well I'm running a good 10 miles an hour fast, at 25 and 35. Then at 45 it spreads out a bit more. I have a 4X2 with a turbo 400, using a 44 tooth gear in a 40/45 housing.
I have here a 40T and a 41T gear, do you think these will help me get closer to my correct goal? I'm running the stock steel 16X7 wheels, and 215/85R16 tires on all four corners. I know more info is needed, just thought someone might know right off hand. Thanks Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 08-24-2016, 01:30 PM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: A little speedo gear help needed please.
Go to TCIAUTO.COM they have a calculator in the technical resource section that will tell you exactly what gears you need. 3 of the following 4 are needed to figure out the fourth.
Tire size or Diameter
rear end gear ratio
drive gear tooth count
driven gear tooth count.
Drive gear is on the output shaft of the transmission. Count teeth thru speedo housing hole or take off tail housing to count.
GRADYS Performance is offline   Reply With Quote
Old 08-24-2016, 03:54 PM   #3
MikeB
MikeB's Avatar
Hey Ken, are you saying the truck is actually moving approx 10 mph faster than indicated by the the speedo at 25-35 mph?
If that's the case, you'll need to make the driven gear spin 30%-40% faster. So if you currently have, for example, 10/44, you will need to go to somewhere around 14/40 if I did the math right, and that's a big if.
Also, I'd check actual vs. indicated speed at 30 mph and 60 mph and determine how far you're off percentage-wise. If it's 33% at one speed and 37% at the other, then try to get as close to a 35% ratio change as possible. Or if you do a lot of highway driving, then focus on the speedo being most accurate at 60-70 mph.
A good way to check actual road speed is with a free smart phone app.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-28-2016, 08:55 PM   #4
1970pelle
1970pelle's Avatar
Thanks Mike. I had a Black and Yellow gear here at the house. The Black gear took care of my issue. I know I could fix it without going though all the jumping through hops and stuff. I simple calculator is all I need. Ken
― Ronald Reagan
Old 08-31-2016, 09:17 AM   #5
Marshy
This is one issue that I need to resolve on my truck but just don't know where to begin. Can anyone point me to where the speedo gears are located on a '84 K10?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 08-31-2016, 03:20 PM   #6
83GMCK2500
Transfer case output shaft and the cable drive. In cutaway pic the green and gray gears. Follow speedo cable back to transfer case and look for the drive (other pic) where it's clamped into the rear housing of the NP208.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
