Old 10-04-2016, 10:42 AM   #1
72kool
72kool's Avatar
what do i have???
im trying to find parts for a rear end rebuild and i do not know what spline count my axles are. the truck is a '72 GMC C25 with the dana 60 rear differential and 4.10 gears. what spline count did these come with? the obvious answer would be to pull the axles and count but i want to get the parts here before i tear into it. also , are there any good seal and bearing kits out there? otherwise i was going to just get what i could from rockauto for good prices. the plan is the replace the axle bearings and seals, check insides for any wear and swap insides for either a powertrax no-slip or spartan locker, and then clean and paint housing. any thoughts or suggestions are welcomed
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
Old 10-04-2016, 10:59 AM   #2
LongBox
Re: what do i have???
Well, assuming it's an 8 lug, pulling an axle is so easy...you don't even have to jack the truck up. And that way, you will know whether you are ordering the right parts.
Just undo the circle of bolts that holds the flange on the axle to the hub, and pull it out. Goes back in just as easy.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-04-2016, 02:28 PM   #3
SS Tim
SS Tim's Avatar
It "should" be a 30 spline with either the 127" or 133" wheelbase.
SS Tim is offline   Reply With Quote
Old 10-04-2016, 02:40 PM   #4
BILT4ME
Tim, do you have the sheets that would include the K25 for 1970? I have a K25 for 1970 and I have an axle assy from a 72 C20 and want to confirm what parts I can use from it.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 10-04-2016, 02:35 PM   #5
68350
68350's Avatar
I just pulled my Dana 60 apart in my 71. 30 spline axles. Sent moser measurements and they are making me a new set. Also I used the timken drk331 bearing and seal kit
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-04-2016, 02:51 PM   #6
SS Tim
SS Tim's Avatar
Just Google X510-8DSD pdf (~3MB) for your own copy.
"This catalog contains applications and part listings for front and rear axles which fit vehicles from model
years 1967-1978. For information on model years between 1978-1998, please refer to catalog X510-9DSD.
For miscellaneous models from years 1979-1984, please refer to X510-7DSD"
Info everyone with a D60 "should" have. BOM numbers are a great way to confirm what you have or are looking at.
Old 10-04-2016, 03:22 PM   #7
BILT4ME
Thanks Tim!
Nice to have for myself!
I appreciate it!
You know much that is hidden, O' Tim.
https://www.youtube.com/watch?v=JTbrIo1p-So
1970 GMC K2500
Old 10-04-2016, 03:58 PM   #8
SS Tim
SS Tim's Avatar
MP's Tim, the Enchanter.... thats great! :-)
Did you have any problem downloading the PDF file?
Unfortunately the good Dana link www.2dana.com/pdf/x510-8dsd is apparently dead, time for more research....
Old 10-04-2016, 05:43 PM   #9
BILT4ME
Yes, but not at the Dana location.
See below.
http://www.canadawideparts.com/downl..._X510-8DSD.pdf
There you have it.
Stop saying the word!
How do I know to stop saying it if you don't tell me what it is?!?!?
1970 GMC K2500
Old 10-04-2016, 05:56 PM   #10
SS Tim
SS Tim's Avatar
Thanks, now every one has a working link.
Got "it".
