1966 Automatic Column - Finished Product
Pictures of my 66 automatic column after assembly, still need to find a nice shift lever as the ones I have are rusty.
If I can find a horn I want to use my 65 custom wheel, instead of the 66 custom wheel I have. Last edited by Johns66; 12-31-2016 at 04:19 PM. Reason: Add to narrative |
![]() Join Date: May 2010
Re: 1966 Automatic Column - Finished Product
Looks great, Nice job.
It only has original paint once |
![]() Join Date: Oct 2006
very cool!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Aug 2004
Nicely done! I have a couple Auto's I'd like to rebuild like that.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks guys, I posted some pictures of the top pieces coming apart and have more of the entire disassembly if anyone wants them.
If you rebuild one do yourself a favor and buy the Napa D6202, American Autowire or the more expensive Classic Truck parts turn signal assembly. (I believe they have two listed) |
Nice job looks good. How rusty is your shift lever? I've had some pretty good success using fine steel wool and WD-40. Might get you by till you find a replacement.
#7 | |
![]() Join Date: Feb 2016
Well done John! That is a very nice column!
Posted via Mobile Device |
Any chance you have pictures of what holds the steering rod centered? Mine is has alot of play up, down, right and left and im wondering if theres a bearing inside that went bad.
