Old 01-16-2017, 08:39 PM   #1
C.20
C.20's Avatar
Need Help Dont No What Else To Do
Hows everyone doing i got a problem with my 1971 chevy c20 350 sbc so recently after this snow storm in north carolina the truck would not turn on so me and my son did i tune up changed the cap,rotor,igniton module,spark plugs,wires the truck turned on we went down the road and all we got was horrible backfire so we thought it was the carb so we changed the carb and it still did it but it got better until u gave the truck alot of gas and it was back to backfiring i dont no what else to do if someone has some advice that will help us out a lot because its my sons daily driver!!
Smoke Tires Not Drugs
C.20 is offline   Reply With Quote
Old 01-16-2017, 08:48 PM   #2
Shinysideup
Shinysideup's Avatar
Re: Need Help Dont No What Else To Do
Timing is off, or maybe fuel line/filter is clogged up.
Shinysideup is offline   Reply With Quote
Old 01-16-2017, 09:46 PM   #3
C.20
C.20's Avatar
Replaced the filter already i havent checked the line will check tommorow
Old 01-16-2017, 08:51 PM   #4
Rickysnickers
Rickysnickers's Avatar
Check for vacuum leaks, maybe .
Old 01-16-2017, 08:54 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
Check your firing order on the plug wires
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-16-2017, 09:48 PM   #6
C.20
C.20's Avatar
alright im goona check again for this but wouldnt it always be back firing if the fireing order is off?
Old 01-16-2017, 09:49 PM   #7
C.20
C.20's Avatar
im goona look into this tommorow
Old 01-16-2017, 09:00 PM   #8
paul blair
Check fuel pump--filter--line
paul blair is offline   Reply With Quote
Old 01-16-2017, 09:47 PM   #9
C.20
C.20's Avatar
replaced the fuel pump already and the filter havent done the line yet
Old 01-16-2017, 09:57 PM   #10
garyd1961
Check the firing order, also make sure the distributor cap is seated properly. It depends on which wires are crossed as to how it will or will not backfire.
garyd1961 is offline   Reply With Quote
Old 01-16-2017, 10:30 PM   #11
C.20
C.20's Avatar
the firing order seems to be ok im goona check it again tommorow and im also goona check the cap and see if its sitting right
Old 01-16-2017, 10:36 PM   #12
paul blair
Any unusual engine noise? How many miles on engine?
Old 01-16-2017, 10:41 PM   #13
C.20
C.20's Avatar
nah no weird noises never had any weird noises once the storm hit it all hit the fan idk whats wrong with it
Old 01-16-2017, 11:37 PM   #14
jocko
jocko's Avatar
Can you elaborate on "would not turn on"? Would not crank? Would not fire/start? I assume the latter since you got backfiring (guess I just answered my own question, sorry...) The items you initially changed out sound like you had indications of no spark. You mentioned after a storm and ign module (as in HEI module?) - perhaps struck by lighting? I think if you changed the HEI module, it'd take care of any lightning damage. Hmm. More details please. It the backfiring load-dependent? Like, only when you let off the gas, for example? Or only when you step on the gas, etc? Sure sounds like a timing issue to me - but that wouldn't just change overnight after a storm. So, you may have two problems - perhaps module went out, and then, during reassembly, the plug wires or timing got crossed/set wrong(?) Backfiring is "normally" a timing/ignition issue - not a carb or fuel issue. Did you replace all the ignition components at the same time and then try to start, or one at a time and try to start? (I'd have done them all too... but that is how compound/self-induced issues can be masked). If it wouldn't start AT ALL (as in no ignition, but it did crank over) and then you changed all the ignition parts and it starts but backfires - my guess is something was messed up in the replacement process while the root problem was fixed.
Old 01-17-2017, 12:38 AM   #15
wbc409
How often does it actually get cold enough to snow there? Did you let the truck warm up, is your choke working?
wbc409 is offline   Reply With Quote
Old 01-17-2017, 02:20 PM   #16
C.20
C.20's Avatar
not much dont snow much either but im running out of ideas im thinking it might be the distributor going
Old 01-17-2017, 02:22 PM   #17
C.20
C.20's Avatar
checked everything you guys told me check everything is good the only thing left i can think of is a warped manifold or a bad distributor
Old 01-17-2017, 02:19 PM   #18
C.20
C.20's Avatar
It backfires when i drive it mostly not when i start it turns right on no problem im running out of ideas
Old 01-17-2017, 02:35 PM   #19
Alex V.
Alex V.'s Avatar
Is it a points-type distributor or HEI electronic?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 01-17-2017, 02:40 PM   #20
C.20
C.20's Avatar
Originally Posted by alex v. View Post
is it a points-type distributor or hei electronic?
hei
Old 01-17-2017, 02:41 PM   #21
wbc409
If you have a points distributor, you could have a bad condenser. I had a condenser go bad once, the truck backfired so hard it blew the end of the muffler off.
Old 01-17-2017, 02:57 PM   #22
C.20
C.20's Avatar
im runnning hei
Old 01-17-2017, 03:00 PM   #23
Deer_hunter_088
Deer_hunter_088's Avatar
Dist gear could be warn, and it could have jumped a few teeth.
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 01-17-2017, 03:02 PM   #24
C.20
C.20's Avatar
hm i didnt think of that it is a offbrand distributor
Old 01-17-2017, 04:20 PM   #25
Deer_hunter_088
had an atv that did that, but the coil sparked bc of stator position, and it jumped timing, and it did EXACTLY what yours is doin. jumped like 3 teeth. pull dist and check On that style of atv, a lil raised pad acted as the rotor on your dist, so when it struck a certian point it fired, when the timing jumped, the valves would open at the wrong time, so it sparked wrong and ran like CRAP at idle, get up in rpms and it went away, but was a lil down on power.
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
