OT: Buick
My wifes car has been running a little hotter than normal lately (210- 216) when you are sitting still.Start moving and it goes back down to 196 Ichanged the thermostat when she got home today didn't seem too help thanks in advance its a 2001 lesabre
Same thing happens to my dad olds 88 every few years. Take a hose and spray off the front of the radiator. It always seems to get clogged with crap every few years. You might have to disassemble part of the shroud. Not hard to do. You will be amazed at the crap that will come out.
Just sitting here contemplating contemplation. |
thanks but thought of that first ,I havta do that on a regular basis because of the trees blowing leaves in the carport
2004 Extended cab LS silverado ![]() 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
Are your fans running
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl ![]() 05 Jeep Grand Cherokee-HEMI powered ![]() 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
yes but only with the air on i couldnt find at what temp. they are supposed too come on in my manual
its all about the +6 inches
They should be coming on around 200 or so, test the sensor in the rad, I think in the lower part.
Sounds like one of the fan relays has died, they're supposed to come on at a preset temp, whether or not the A/C is on
IIRC the temp is around 225*
I'll check it out more sunday it getting dark earlier now barely had time to do the thermostat this evening my 68 is residing in her parking spot
The relay would be a pretty good place to look too, could just swap it out with the A/C relay and turn on the A/C and see if the fan kicks on.
