05-10-2017, 09:24 AM | #1 |
dana 60 spacer to fit hubcaps
Sorry, I cannot find the thread I saw a while back, am looking for offset spacer plate to be bolted onto rear hub so I can fit the 73+ yrs hubcaps over those big dana 60's that stick way out.
05-10-2017, 09:52 AM | #2 |
Re: dana 60 spacer to fit hubcaps
There must be different Dana60 rear hubs because I have no problem running the 73-75 hubcaps on my K2500 with Dana60. I prefer the later cocave with no black paint and that's what I have always run on my '72
05-06-2018, 01:01 PM | #3 |
those caps look period correct for a 3/4 ton. the half ton caps are much shallower and won't clear the 3/4 dana 60 hub.
its not just for that reason, i run tall skinny 235/85r-16 tires and they would look better if they weren't so tucked in the rear wheel wells, there are lots of spacer plates but some are better than others, anyone know of which brands are well made and applicable to our old C20's ? |
05-06-2018, 01:12 PM | #4 |
1/2 ton caps are too small a diameter for 3/4 ton wheels anyway, the 3/4 ton caps from 69-75 will fit over your rear end. 69-72 were chrome outies (i.e. convex center emblem), whereas 73-75 were stainless, some were innies and some were outies. Just paint the center emblem Krylon "True Blue" if you use a 73+ cap and you're good to go. 1st pic is a true 69-72 chrome 3/4 ton PO3 "outie". Pic 2 is a 73-75 stainless 3/4 ton PO3 "innie", with bow tie painted. Both trucks had D60s and the caps clear fine - there is no need for a spacer to bump the wheel out with either an innie or an outie 3/4 cap from 69-75.
EDIT: I'm not tracking where the 1/2 ton comment is coming into play(?) Can you confirm you're talking about a 3/4 ton or above 8 lug rear? If you just want to space out the rear to move the tires out in the wheelwell, then that's a different story - but it's not necessary to make concave PO3 3/4 ton caps fit over a D60. EDIT 2: http://67-72chevytrucks.com/vboard/s...d.php?t=597062 Post 8 has a link to a reputable spacer mfgr. Another spacer and cap discussion http://67-72chevytrucks.com/vboard/s...d.php?t=654690 Last edited by jocko; 05-06-2018 at 01:35 PM. |
05-06-2018, 04:45 PM | #5 |
sorry to bother on this post, got info I needed from youtube....should have looked there first.
05-06-2018, 04:52 PM | #6 |
here's my wheel
05-06-2018, 07:37 PM | #7 |
Those hub caps are 77-91 truck caps as well as the 77-95 Van caps which used a 14 bolt rear. The Dana 60 has a longer hub than a 14 bolt.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
05-06-2018, 07:36 PM | #8 |
That's a 76+ 3/4 ton front 4x4 cap, but you probably already know that
