Old 05-11-2017, 01:58 AM   #1
RBW
RBW's Avatar
New cab pads too thick for my '62
Just finishing some rust repair in the floors of my '62 C10 and am about to replace the cab pads. Ordered a set that's supposed to fit '60-'66, but the ones the Truck Shop in Orange, CA sent appear to be way too thick and shaped differently. I've head nobody is making pads specifically for the '62, so adapting the ones like I might be the only option. Questions:
1) Does anyone make cab pads that are the same size and shape as OEM pads?
2) If not, should I just shave the ones from the Truck Shop down to the proper thickness?
3) Mine are squished enough that it's hard to tell exactly how thick the top and bottom ones should be. Does anyone have specs on these?
4) As far as shaving the new ones down, what's the best way to do this? Cut them? Grind them? Or??
Thanks for any help with this.
RBW is offline   Reply With Quote
Old 05-11-2017, 07:06 AM   #2
PGSigns
PGSigns's Avatar
Re: New cab pads too thick for my '62
What you have looks about right on the new ones. Your old ones started life that size.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-11-2017, 09:56 AM   #3
Bears63
...just another truck junkie..
Bears63's Avatar
You figure over 50 years of weight, vibration and shock and those rubber bits get smashed down a long ways.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-11-2017, 10:07 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Don't cut them down! Be sure you install the bushings and hardware in the correct order, then correctly torque down the assembly.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-12-2017, 08:03 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I agree.
If he replaces them all for also the bed and the core supports, things should line up.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-11-2017, 02:33 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Good thread on it: http://67-72chevytrucks.com/vboard/s...d.php?t=630707
Old 05-12-2017, 02:35 AM   #7
RBW
RBW's Avatar
Originally Posted by The Rocknrod View Post
After looking at that thread, I'm even more inclined to believe the 60-62 cab mount pads are not the same as the 63-66. Not sure if they're square as (as shown in the other thread) but sure do appear to be thinner. And it doesn't look like my '62 was set up for the cone shaped pads. If I were to install the "60-66" kit that I now have, the cab would sit about an inch higher and the body lines would not match the lines on the bed.
Old 05-12-2017, 09:50 AM   #8
vin63
vin63's Avatar
The cone-shaped bushing is installed on the underside of the rear cab mount bracket. Is your bracket different than the one pictured?
Old 05-12-2017, 11:09 AM   #9
oldusafmsgt
oldusafmsgt's Avatar
The original type 60-62 cab mounts are not reproduced. However, the 64-66 cab mount pads work fine, but require the bolts to be about 1 inch longer, so replace the bolts with longer grade 8 or better. DO NOT SHAVE THE PADS.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 05-12-2017, 11:55 AM   #10
RBW
RBW's Avatar
[QUOTE=vin63;7940935]The cone-shaped bushing is installed on the underside of the rear cab mount bracket. Is your bracket different than the one pictured?
Thanks for posting that pic. Looks like the mounts on my '62 are actually quite similar to what you're showing. Guess I'll go ahead and try installing the cab pads without modifying them. I'll get some longer bolts, as suggested.
Old 05-12-2017, 01:02 PM   #11
61K10
61K10's Avatar
My 61's were square and had some sq metal flat spacers about 1/8" thick. I used the later ones and they fit fine after the longer bolts.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-12-2017, 01:07 PM   #12
RBW
RBW's Avatar
Are longer bolts required on all 4 corners?
Old 05-12-2017, 01:41 PM   #13
61K10
61K10's Avatar
I think only the 2 back ones? been awhile.
1961 chevy K10
