Always on the hunt...
![]() Join Date: Sep 2006
Just pulled out two manual throttle control setups complete with everything needed to add the K31 option to your truck, if needed will swap out the standard control knob and gas pedal on either setup to the deluxe stainless knob/pedal set (last pic) for $25. more. Payment can be sent via US postal money order, paypal or credit card over the phone. Thanks, Mel.
![]() Setup #1 / OE 71 Manual throttle pedal setup complete with good working adjustment cable, dash bezel "throttle" plate, standard black control knob and gas pedal. $150...*Sold & Shipped* As of 05/30/17, we do currently have more of this style pulled/ready to ship, can add to thread if interested. Setup #2 / OE 72 Manual throttle pedal setup complete with good working adjustment cable, dash bezel "throttle" plate, standard black control knob and gas pedal. $150...*Sold & Shipped* Last edited by Classic Bowties; 05-30-2017 at 09:45 PM. Reason: Updated availability |
Re: 1971 & 1972 C/K RPO K31 Manual Throttle & Gas Pedal Setups
72 Setup...
![]() Join Date: Aug 2013
I'll take the 72 one. Option 2 with deluxe setup
Hi Eric, here are some pictures of the second requested 72 K31 manual throttle setup, this one was removed from a 72 cheyenne so it already had the deluxe stainless control knob and gas pedal trim. Also per your request, I have swapped the above pictured separate deluxe stainless control knob & pedal over to first committed 72 throttle setup. Last two pictures are showing both of your 72 manual throttle setups with deluxe stainless knobs & gas pedals side by side. Thanks, Mel.
Both 72 setups side by side...
Hi Eric, your two above pictured 72 manual throttle control setups both w/deluxe stainless are under way, the package went out USPS priority on Sun. 05/28 and the projected delivery date listed on the postal receipt is next Thu. 06/01. Thanks again for the purchases and let us know if you have any questions on the install, Mel.
Active Member
![]() Join Date: Dec 2003
do you still have an other 72 throttle setup?
We have sold the four 72 K31 setups that we had stashed away in the last week and only have the 71 type manual throttle setups pulled/available at this time. The 71 setup will also bolt into and function correctly on a 72 truck, its just the pedal rod, pedal support bracket and lower control cable mounting provisions that are a little different between the two years. Mel
![]() Join Date: May 2012
morning, do you have the deluxe knob for the '71?
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
hey Mel, I'll take the '71 with the deluxe knob sending paypal
mike
#13 | |
Wow Mel,
I just pulled it out of the package. thank you for the bolts holding it together so I can put it in correctly. You are now my main supplier!! mike
#15 | |
#16 |
Mel, I'm sorry I tried to edit the other post and ask for your info but???? please send info
mike
#17 |
#18 |
thanks Mel, PayPal sent
mike
#19 |
Hi Mike, no paypal funds have been received from you as of 2:00 pst today 05/28, you may want to check on the payment address that your funds were sent to, I just double checked the address/payment id that was sent to you yesterday and it is correct. Please confirm your full shipping address and we will get the 71 manual throttle setup ready for shipment. Thanks, Mel.
#20 |
Mel, I apologize , I put your payment info in wrong. I did it again so I hope everything comes out right
mike
#21 | |
#22 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Are the cables interchangeable between 71 and 72? Looks like 72 cables have rubber outer covering not present in 71 so wondering if there’s another difference like length.
EDIT: Part number is the same for 71-72. Wonder if the rubber sleeve/hose was added on the line at assembly?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 03-29-2020 at 08:48 PM. Reason: Added |
#23 |
On a 1971 chevy pick up were does the other end of the Manuel throttle bracket bolt up to, the bracket that holds the cable.
