Old 07-02-2017, 04:09 PM   #1
LT102
LT102's Avatar
Vacuum source
Which is the better source for vacuum, from the carb or from the intake manifold? Or is there no difference?
LT102 is offline   Reply With Quote
Old 07-02-2017, 04:16 PM   #2
toolboxchev
Re: Vacuum source
For what purpose? For most everything it would be off the intake manifold.
For vacuum advance off the carb. The non timed port of course.
toolboxchev is offline   Reply With Quote
Old 07-02-2017, 04:20 PM   #3
Wrenchbender Ret
Re: Vacuum source
There are different type vacuum outlets. It depends on what you are running it too to know which you need to use. Give your year model & engine size & what you want to send vacuum to & I or some other Stovebolters can answer.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-02-2017, 05:53 PM   #4
LT102
LT102's Avatar
Re: Vacuum source
Engine is 350, bored .30 over with mildly aggressive cam. Main concern is vacuum to the power brake system.
Old 07-02-2017, 05:57 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Vacuum source
Intake manifold vacuum for sure.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
