Old 08-05-2017, 04:05 AM   #1
5spd540
Under bed fuel tank for ls swap and fuel system
What are you guys using for a tank and fuel system for your LS swap? I just ordered my engine and trans yesterday so now I need to get started on a fuel syetem
5spd540 is offline   Reply With Quote
Old 08-05-2017, 11:43 AM   #2
lilred2
lilred2's Avatar
Re: Under bed fuel tank for ls swap and fuel system
I have a Boyd Welding tank in mine and like it. Reasonable price for a custom tank also.
lilred2 is offline   Reply With Quote
Old 08-05-2017, 11:45 AM   #3
5spd540
I looked but all I saw was a carb tank not one for efi.
Old 08-05-2017, 12:05 PM   #4
5spd540
Old 08-05-2017, 01:05 PM   #5
lilred2
lilred2's Avatar
This is the one I have. http://www.fueltankparts.com/67-72-e...side-fill.html
Old 08-05-2017, 01:30 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Boyd do a bed fill EFI tank
http://www.fueltankparts.com/67-72-e...-bed-fill.html
or a side fill
AussieinNC is offline   Reply With Quote
Old 08-05-2017, 02:09 PM   #7
Oldblue68chevy
Boyd tank here. The only issue i had was the connector crimps in the tank were not crimped all the way. Whoever did the wiring limp wristed the crimps. Double check them before installing. The tank is perfect though.
Oldblue68chevy is offline   Reply With Quote
Old 08-05-2017, 05:13 PM   #8
1quik70
I bought a Blazer tank from Brothers, and cut a hole in the top for the drop in Holley pump.
https://www.holley.com/products/fuel...e/parts/12-130
I did a bunch of research and thinking and decided to give this setup a try and I really like it so far! Super easy to install, and almost zero pump noise!!!
I ran 3/8" Stainless lines down the frame rails for feed and return, and used -6AN stuff to plumb to the pump, and regulator.
1quik70 is offline   Reply With Quote
Old 08-05-2017, 05:48 PM   #9
MachinistRandy
I'm currently installing a 87 Jeep Wrangler tank. Inside I'm using a 87 Blazer sending unit, and a ep381 fuel pump. Surprisingly, everything fits without any modifications. Only modification to the truck is trimming one of the bed rails, cutting a hole for the filler, and removing the spare tire crossmember. The two downfalls I've found so far.....no tank baffles, and only 15 gallon fuel capacity. We will see as soon as it's running!
MachinistRandy is offline   Reply With Quote
Old 08-06-2017, 01:17 AM   #10
Robznob11
Robznob11's Avatar
Well you have to notch the bottoms of the rails, and move the rear member towards the rear, but its cheap, it works and there are race pump upgrades ready available! 01-02 plastic f body tank! Oh and you have to use a hole saw for the filler to pass through the frame as well! Sorry I could not find any better pics but you get the idea!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-06-2017, 08:43 AM   #11
ozarks hunter
I'm doing a LS swap in a 72 and am also trying to decide which tank to go with. The decision making is the toughest part on some of this stuff lol.
I really like the idea of the Boyd's so far.
ozarks hunter is offline   Reply With Quote
Old 08-06-2017, 08:52 AM   #12
pappy 2
Get a FI tank from Boyd Tanks. Also get the install kit, another $40 or so. Even I was able to get it installed with no problem.
pappy 2 is offline   Reply With Quote
Old 08-06-2017, 09:39 AM   #13
Leonard1
Leonard1's Avatar
I used an '87 suburban fuel tank, no cutting supports, no notching the frame...
http://67-72chevytrucks.com/vboard/s...highlight=tank
Leonard1 is offline   Reply With Quote
Old 08-10-2017, 01:17 PM   #14
68blazer
68blazer's Avatar
your link doesn't show or talk about your project being complete. do you have an update or pics of your work? I would love to see updated pics of how good it fits, or a completed project, etc..
68blazer is offline   Reply With Quote
Old 08-07-2017, 06:31 PM   #15
lutronjim
I used one from a GTO and had the filler go through the bumper with a fold down tag.
http://www.tanksinc.com/index.cfm/pa...rod/prd378.htm
lutronjim is offline   Reply With Quote
Old 08-07-2017, 08:13 PM   #16
elf w/capital T
repop blazer side fill tank, custom fitted blazer filler and in bed cover. time being inline pump in fuel rail with the vette regulator... soon to be going TANKS INC PA-4 in tank fuel pump due to annoying whine.
elf w/capital T is offline   Reply With Quote
Old 08-09-2017, 09:35 AM   #17
Money_pit
Money_pit's Avatar
Also bought the Boyd's. Awesome quality,perfect fit. Would surely buy again.
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 08-09-2017, 09:55 AM   #18
lilred2
lilred2's Avatar
I had a blazer tank in mine originally and while it held more fuel than the Boyd tank it just sat to low. I didn't like how visible it was when you were standing behind the truck. I think if I would have had the Boyd tank powder coated black you wouldn't even know it was there.
Old 08-09-2017, 02:38 PM   #19
boraxman
Keepin an eye out
boraxman's Avatar
I have a Boyds ready to go in, bed fill, mounting kit, pretty deluxe cost ~800
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-10-2017, 08:13 PM   #20
NC_John
NC_John's Avatar
Same here. The only problem i have is the tank is too pretty to hide under the bed.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-11-2017, 07:36 PM   #21
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Originally Posted by NC_John View Post
Same here. The only problem i have is the tank is too pretty to hide under the bes.
I too have this Boyd's tank and agree it's to pretty to hid LOL
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-10-2017, 06:25 AM   #22
Leonard1
Leonard1's Avatar
I know the '87 tank is not custom, but it fits well between the frame. Best part is the price, about $200 total, including the sending unit and pump.
Old 08-10-2017, 11:53 AM   #23
scoot_mcgrute
I'm using a top fill LMC tank with a Walbro 255 inline pump and Corvette regulator on mine (I have an LS1 returnless fuel rail). It works really well for me
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-11-2017, 11:46 PM   #24
Blazerowner
Blazerowner's Avatar
I just ordered a Boyd's for my blazer. The good thing about them is they will put the filler anywhere you want.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 08-12-2017, 08:19 AM   #25
truckdude239
truckdude239's Avatar
I used a 87 suburban fuel tank and sender unit with an ac delo ep381 fuel pump
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
