Under bed fuel tank for ls swap and fuel system
What are you guys using for a tank and fuel system for your LS swap? I just ordered my engine and trans yesterday so now I need to get started on a fuel syetem
Re: Under bed fuel tank for ls swap and fuel system
I have a Boyd Welding tank in mine and like it. Reasonable price for a custom tank also.
This is the one I have. http://www.fueltankparts.com/67-72-e...side-fill.html
Moderator
![]() Join Date: Jun 2017
Boyd do a bed fill EFI tank
http://www.fueltankparts.com/67-72-e...-bed-fill.html or a side fill http://www.fueltankparts.com/67-72-e...side-fill.html ![]() ![]() ![]() |
Boyd tank here. The only issue i had was the connector crimps in the tank were not crimped all the way. Whoever did the wiring limp wristed the crimps. Double check them before installing. The tank is perfect though.
I bought a Blazer tank from Brothers, and cut a hole in the top for the drop in Holley pump.
https://www.holley.com/products/fuel...e/parts/12-130 I did a bunch of research and thinking and decided to give this setup a try and I really like it so far! Super easy to install, and almost zero pump noise!!! I ran 3/8" Stainless lines down the frame rails for feed and return, and used -6AN stuff to plumb to the pump, and regulator. |
I'm currently installing a 87 Jeep Wrangler tank. Inside I'm using a 87 Blazer sending unit, and a ep381 fuel pump. Surprisingly, everything fits without any modifications. Only modification to the truck is trimming one of the bed rails, cutting a hole for the filler, and removing the spare tire crossmember. The two downfalls I've found so far.....no tank baffles, and only 15 gallon fuel capacity. We will see as soon as it's running!
Well you have to notch the bottoms of the rails, and move the rear member towards the rear, but its cheap, it works and there are race pump upgrades ready available! 01-02 plastic f body tank! Oh and you have to use a hole saw for the filler to pass through the frame as well! Sorry I could not find any better pics but you get the idea!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
I'm doing a LS swap in a 72 and am also trying to decide which tank to go with. The decision making is the toughest part on some of this stuff lol.
I really like the idea of the Boyd's so far. |
Get a FI tank from Boyd Tanks. Also get the install kit, another $40 or so. Even I was able to get it installed with no problem.
I used an '87 suburban fuel tank, no cutting supports, no notching the frame...
http://67-72chevytrucks.com/vboard/s...highlight=tank |
![]() Join Date: Dec 2013
I used one from a GTO and had the filler go through the bumper with a fold down tag.
http://www.tanksinc.com/index.cfm/pa...rod/prd378.htm |
#15 |
repop blazer side fill tank, custom fitted blazer filler and in bed cover. time being inline pump in fuel rail with the vette regulator... soon to be going TANKS INC PA-4 in tank fuel pump due to annoying whine.
#16 |
Also bought the Boyd's. Awesome quality,perfect fit. Would surely buy again.
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() |
#17 |
I had a blazer tank in mine originally and while it held more fuel than the Boyd tank it just sat to low. I didn't like how visible it was when you were standing behind the truck. I think if I would have had the Boyd tank powder coated black you wouldn't even know it was there.
#18 |
Keepin an eye out
I have a Boyds ready to go in, bed fill, mounting kit, pretty deluxe cost ~800
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#19 |
I know the '87 tank is not custom, but it fits well between the frame. Best part is the price, about $200 total, including the sending unit and pump.
#20 |
I'm using a top fill LMC tank with a Walbro 255 inline pump and Corvette regulator on mine (I have an LS1 returnless fuel rail). It works really well for me
#21 | |
#22 |
Same here. The only problem i have is the tank is too pretty to hide under the bed.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 Last edited by NC_John; 08-11-2017 at 10:44 PM. |
#23 | |
Senior Moment
![]() Join Date: Mar 2002
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#24 |
![]() Join Date: Apr 2006
I just ordered a Boyd's for my blazer. The good thing about them is they will put the filler anywhere you want.
Kirk 72 Blazer CST 4wd highlander Last edited by Blazerowner; 08-12-2017 at 12:21 PM. |
#25 |
![]() Join Date: Sep 2005
I used a 87 suburban fuel tank and sender unit with an ac delo ep381 fuel pump
