![]() Join Date: Apr 2005
Cheyenne Super glove box door placard/overlay
What's the best way to attach the aluminum Cheyenne overlay onto my glove box door? Liquid nails? 2 sided 3M tape? Tips or suggestion would be great. TIA.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Cheyenne Super glove box door placard/overlay
3m 77 spray adhesive works good.
It’s basically sprayable contact cement. Spray both pieces and let them dry. Then stick it.. But you better have it where you want, because it will be stuck! Tape off the glovebox door where you don’t want glue. Lots of good videos on using this stuff.
is that aftermarket woodgrain? if it is where did you get it?THANKS
Any contact cement will work. Use some piano wire or old hangers to hold the inlay just above the door after the glue is ready. Then you can get it aligned with out sticking. Then starting at one edge lineup and remove the wires one by one working across. Don't press down as you go in case your not happy with the alignment before the last wire is removed. When your satisfied pull the last one and use a roller to push air bubbles out from the center to the edges. The spray cement is easier to get a consistent glue application but far messier due to over spray. If you haven't used it before and want to that way do some practicing with the spraying.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Mar 2013
I used 3M emblem tape for my 67's Chevrolet emblem, it has held for 6 or 7 years now. I cleaned both really well before I did it. The bonus of the tape is if I ever need to remove it I have a better chance of getting it off in one piece. Good luck!
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
#6 | |||
Thanks!
I ended up using 3M 2 sided tape and it worked great. Can anyone give me the dimensions/position to mount the actual emblem? Thanks!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-17-2018 at 03:29 PM. |
![]() Join Date: Apr 2013
Do you remember what size/thickness of 3M tape you used?
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
#9 | |
Mr. Cheyenne
![]() Join Date: Jun 2020
Might you recall the 3M sided tape you used? Was it actually their mounting tape? It seems kind of thick but I suppose photos on Amazon can be misleading. I actually have some 3M double-coat 665 tape - which is thin but I don't think it would be strong enough.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
Mr. Cheyenne
well, i got some 3M Super Strength Molding Tape, 03614, 1/2 in x 15 ft from O'Riley's. I had a $5 reward and figured give it a go.
The stuff worked great and its a little squishy, so I think the aluminum overlay went on very well.
bump
Nobody is able to help you with that, as no one else has that emblem.
I guess you will just have to send it my way.
#13 | |
Rob, I'm not sure if I love you, the 'burb, or both! That emblem is *****IN!!! I am completely stunned! I love it!
#15 |
Just the 1 emblem, that can't be right. Billet SUPER-BURB side emblems? Billet Tailgate emblem? Hood ornament?...FYI when you type in Superburb in google search it auto corrects to..... SUPERB......Nice Bonus...Well Done....
#16 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Have you seen his tailgate yet? Pretty sweet, good work Rob. If you need a measurement, I can probably help out. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#17 |
![]() Join Date: Aug 2003
I hooked tape measure on edge of aluminum.
#18 |
222222
#19 | |||
Glad you like it! ![]() ![]() Quote:
![]() ![]() Quote:
![]() ![]() ![]() Thank you Tim!!! Will post pictures once installed. ![]()
#20 |
I’d say place it where you want.
If you search “Cheyenne super glove box doors”,... you’ll find they were placed in many different locations in the lower right hand corner. I doubt there is an “exact” location.
#21 |
Well since Uncle Tim let the cat out and now there's no chance of the emblem showing up in my mailbox.
I think lowlife99 is right with the different factories and having to stick them on 30-50 times a day per shift as long as they weren't crooked, no one probably cared how exact they got installed.
#22 |
Thanks for all of the input
, sorry I forgot to post a picture, .
#23 |
Looks perfect!
When is the side trim going on your burb?
#24 |
Thanks! UUUuuuhhmmm, working on it.....one thing at a time....
#25 |
I think it was 1/8".
| Bookmarks |
