Old 01-07-2018, 12:03 PM   #1
Hart_Rod
Hart_Rod's Avatar
Cheyenne Super glove box door placard/overlay
What's the best way to attach the aluminum Cheyenne overlay onto my glove box door? Liquid nails? 2 sided 3M tape? Tips or suggestion would be great. TIA.
Hart_Rod is offline   Reply With Quote
Old 01-07-2018, 12:28 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Cheyenne Super glove box door placard/overlay
3m 77 spray adhesive works good.
It’s basically sprayable contact cement.
Spray both pieces and let them dry.
Then stick it..
But you better have it where you want, because it will be stuck!
Tape off the glovebox door where you don’t want glue.
Lots of good videos on using this stuff.
Keith
Convert to disc brakes.
Old 01-07-2018, 01:02 PM   #3
1968aj
is that aftermarket woodgrain? if it is where did you get it?THANKS
1968aj is offline   Reply With Quote
Old 01-07-2018, 06:33 PM   #4
HO455
HO455's Avatar
Any contact cement will work. Use some piano wire or old hangers to hold the inlay just above the door after the glue is ready. Then you can get it aligned with out sticking. Then starting at one edge lineup and remove the wires one by one working across. Don't press down as you go in case your not happy with the alignment before the last wire is removed. When your satisfied pull the last one and use a roller to push air bubbles out from the center to the edges. The spray cement is easier to get a consistent glue application but far messier due to over spray. If you haven't used it before and want to that way do some practicing with the spraying.
RIP Bob Parks.
Old 01-07-2018, 06:42 PM   #5
Orange67
Orange67's Avatar
I used 3M emblem tape for my 67's Chevrolet emblem, it has held for 6 or 7 years now. I cleaned both really well before I did it. The bonus of the tape is if I ever need to remove it I have a better chance of getting it off in one piece. Good luck!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 01-08-2018, 04:00 PM   #6
Hart_Rod
Hart_Rod's Avatar
Then stick it..
Thanks for the info!
I got the placard from a board member SuperCheyenne Man. He also redid my door panels and gauge bezel.
Good info!
Thanks!
Old 01-17-2018, 03:17 PM   #7
Hart_Rod
Hart_Rod's Avatar
I ended up using 3M 2 sided tape and it worked great. Can anyone give me the dimensions/position to mount the actual emblem? Thanks!
Old 01-19-2018, 09:44 PM   #8
Hart_Rod
Hart_Rod's Avatar
bump
Old 01-19-2018, 10:00 PM   #9
HO455
HO455's Avatar
Nobody is able to help you with that, as no one else has that emblem. I guess you will just have to send it my way.
RIP Bob Parks.
Old 01-19-2018, 10:21 PM   #10
Hart_Rod
Hart_Rod's Avatar
Old 01-19-2018, 10:31 PM   #11
Orange67
Orange67's Avatar
Rob, I'm not sure if I love you, the 'burb, or both! That emblem is *****IN!!! I am completely stunned! I love it!
Justin
Old 01-20-2018, 09:01 AM   #12
notsolo
notsolo's Avatar
Just the 1 emblem, that can't be right. Billet SUPER-BURB side emblems? Billet Tailgate emblem? Hood ornament?...FYI when you type in Superburb in google search it auto corrects to..... SUPERB......Nice Bonus...Well Done....
notsolo is offline   Reply With Quote
Old 01-20-2018, 11:04 AM   #13
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Have you seen his tailgate yet? Pretty sweet, good work Rob. If you need a measurement, I can probably help out. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-20-2018, 11:32 AM   #14
uncle
I hooked tape measure on edge of aluminum.
uncle is offline   Reply With Quote
Old 01-20-2018, 11:32 AM   #15
uncle
222222
Old 01-20-2018, 11:33 AM   #16
uncle
3333333
Old 01-20-2018, 11:34 AM   #17
uncle
4444
Old 01-20-2018, 11:55 AM   #18
Hart_Rod
Hart_Rod's Avatar
Glad you like it!
Thanks!
Thanks Trevor!
Thank you Tim!!! Will post pictures once installed.
Old 01-20-2018, 12:56 PM   #19
lolife99
lolife99's Avatar
I’d say place it where you want.
If you search “Cheyenne super glove box doors”,... you’ll find they were placed in many different locations in the lower right hand corner.
I doubt there is an “exact” location.
Keith
Old 01-20-2018, 04:47 PM   #20
HO455
HO455's Avatar
Well since Uncle Tim let the cat out and now there's no chance of the emblem showing up in my mailbox. I think lowlife99 is right with the different factories and having to stick them on 30-50 times a day per shift as long as they weren't crooked, no one probably cared how exact they got installed.
RIP Bob Parks.
Old 03-21-2018, 06:57 AM   #21
Hart_Rod
Hart_Rod's Avatar
Thanks for all of the input , sorry I forgot to post a picture, .
Old 03-21-2018, 07:34 AM   #22
lolife99
lolife99's Avatar
Looks perfect!
When is the side trim going on your burb?
Keith
Old 03-21-2018, 07:47 AM   #23
Hart_Rod
Hart_Rod's Avatar
Looks perfect!
Thanks! UUUuuuhhmmm, working on it.....one thing at a time.....
Old 02-05-2019, 11:42 PM   #24
rharris
rharris's Avatar
Do you remember what size/thickness of 3M tape you used?
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 02-06-2019, 11:54 AM   #25
Hart_Rod
Hart_Rod's Avatar
I think it was 1/8".
