Garage floor coatings
Has anyone used any specialty garage floor coatings? Specifically, Gorilla Garage or any other Polyaspartic floor covering companies.
Thanks in advance. |
Re: Garage floor coatings
From what I've seen ,a lot of those on here would be suprised to find their garage had a floor ......
Stan 67 swb BLU MULE posted via flip-fone |
#3 | |
![]() 69Canam - JK. In all seriousness, Ive worked on many commercial garages / shops in the area. For a long time, there was only one company that would shoot an epoxy floor. It was called StoneHard. Nice durable commercial finish. I do remember that it was imperative that the concrete was absolutely clean and did not wick any moisture up from below (which meant a base rock or sand base under the pour). The prep was the biggest thing with these guys. The jobs would nearly shut down for a week while they prepped - shot and the fumes would near kill you for up to a week later as it cured. Nice stuff though. Ive seen a lot of different coatings in the home improvement stores as of late and although Ive never tried them in my garage (BC until now I didn't know I had a floor ![]() Not sure if that's what your looking for as far as a recommendation. Hope it helps. If not, cover your floor with parts like the rest of us!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
![]() ![]() Join Date: May 2015
nearly all our plant floors have stonehard on them...very expensive.....I wanted to coat my alleged shop floor with the garage paint but the way things go in my shop Im afraid it wouldn't hold up to good...torch work and welding and dragging stuff around don't go to good with that...
Who Changed This?
![]() Join Date: Jan 2013
6"+ of concrete. It's pretty much impervious to anything, including the pressure from the steel wheels of a floor jack when raising that giant steel pig of a truck off its surface.
I have an epoxy floor in my 25x35 shop. It's pretty durable. Put in by a local guy. I also had them extend it up and do a "molded baseboard".
IMO, you get what you pay for. http://67-72chevytrucks.com/vboard/f...splay.php?f=89 My floor was uneven to start with. Last edited by 95 S_Trucker; 03-07-2018 at 09:37 AM. |
"Tail Gate Best Seat In House"
![]() Join Date: Oct 2007
My neighbor Herb is 87 years old did his garage floor by his self with Epoxy and scattered flakes over it like feeding the chickens,, looks not bad and it sure is good for cleanning ,, to take it up the wall a bit is even better like trucker has done ,,then no problem hosing it out the door .
When you learn a thing a day you store up smart. |
blood type; Retumbo
I use road salt, grease, trans fluid, engine oil and blood
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
How do you guys handle the coated floors being slippery. I had a garage that was coated with something. I bought it that way so I don't know what it was. But you could play hockey on it.
I would try to put my car on my ramps to change the oil and the ramps would just slide around.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
I know the pieces fit
I thought about trying the Rustoleum garage floor kit when I saw it, but the reviews are really mixed. I've decided to go simple and use a premium outdoor latex paint.
#11 | |
I've had ramps slide around on dry pavement and concrete. The only place I could ever get them to not move around was in the grass. Then they would sink. |
I did the DIY Rustoleum kit in my garage and it has started to peel after 6 years from efflorescence pushing up to the surface in the concrete.
The other thing I wanted to note...those flakes of paint that are included in the kit to scatter on the floor make for perfect camouflage for dropped nuts and bolts. I've spent a lot of time looking for that 1/4" washer that dropped when I was putting something together.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
The biggest challenge with painting a concrete floor is the prep. If you don't get that part right, any coating will come off.
I did mine with Rustoleum Metallic and I love it! https://www.rustoleum.com/product-ca...atings/medici/
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
