nv4500 in 69 4wd
New here and hoping for some guidance! I purchased a 69 c10 4x4 that I am taking to the frame and working my way back up. I purchased a 550hp 421 from skip white performance and everyone tells me I need to go up to the nv-4500. Here is where it gets foggy for me... I can buy the tranny but what one do I need, transfer case along with any adapters? I was pointed to advance adapters and sent them a email but have not heard back. Anyone have any advice or a place to turn to?
Re: nv4500 in 69 4wd
Do a search on this site. There are several examples. The transfer case shifter mounting will be custom.
I used a Dodge NV4500 that had the input changed over to a GM and used the Dodge NP205 that bolted right to the 4500 and the whole setup came out less than 1" longer than the SM465/205 combo that it replaced. I used an Advanced Adapters manual clutch linkage bellhousing and their GM transfer case shifter mount.
The shifter mount will need bracing and I made a linkage for the shifter to shift rails connection out of 1/4" all-thread and rod ends. This was the simplest way for me to get the setup I wanted with almost no modification. |
#4 | |
The Older Generation
What trans does the truck have in it now? LockDoc
it has the factory 4 in the floor
Here is how I replaced the SM465 in my '72 Dually with the GM NV4500. http://67-72chevytrucks.com/vboard/s...d.php?t=673588 That way you can use all of the stock clutch parts and you don't need the expensive adapter. I don't know anything about the 4x4 part of it because mine was a 2WD but you should be able to figure that out. LockDoc
You can call these folks and get about everything you need in one stop, www.midwesttrans.com, or you can piece it all together.
It is pricy, if you go with midwesttran.com. |
With my lack of knowledge I would be happy to go the extra $ to have exactly what I need... I am a machinist by trade so I can make just about anything I need... but am clueless to what I need when it comes to this..
The sell a kit like I bought that has everything but a clutch and pressure plate for around $3K. I used a Centerforce Dual Friction clutch and I believe it was an 11". I used my bell crank and linkage and it even came with the spacers for the crossmember.
I'm pretty sure that was for a new, not reman tranny and a reman xfer case. |
