Old 04-08-2018, 09:40 PM   #1
Domingo
1968 c10 died
1968 c10. Died on my son Wednesday, got it home and the fuel bowls empty. I tought fuel pump, replace with a new acdelco from summit racing, now Sunday truck dies again. Replaced the fuel filter as well.
One thing the has me concern the fuel line coming from the tank to the fuel pump it was dry. Could it be a plugged gas pick up it has a 21 gallon gas tank from brothers(blazer) 4 years old
any ideas could it just be another bad pump
Domingo is offline   Reply With Quote
Old 04-08-2018, 10:18 PM   #2
HO455
HO455's Avatar
Re: 1968 c10 died
Could be plugged or since it is a suction line it could have a hole somewhere before the tank allowing it to suck air and not fuel. Or the really annoying and hard to find, flap of loose rubber inside of the hose. ( been there it took days of frustration and some luck to solve)
Test your pump by running a suction line from it to a can of gas and crank the truck to see if the float bowl fills up. With the gas we have to use nowdays it isn't out of the question for a hose to fail in four years.
RIP Bob Parks.
Old 04-09-2018, 02:52 PM   #3
Barnfind46
Barnfind46's Avatar
Re: 1968 c10 died
Could be vaporlock. How warm was it there on the days you had the problem? We have 10% ethanol here and it will start to boil in the fuel line at 190 degrees. We had a couple of 80 degree days and my truck sat down on me. I had a clear fuel filter and I could watch it boil and turn to vapor. Just a thought.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 04-09-2018, 08:10 PM   #4
Rufas
Rufas's Avatar
Re: 1968 c10 died
The fuel sock on the fuel pickup line inside the tank could be plugged. Pull the tank sending unit out and check it
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 04-09-2018, 08:24 PM   #5
Domingo
Re: 1968 c10 died
The temp was about 75, I dont think it was vapor lock.
I'm going to replace all the rubber lines with steel and drop and check the tank
Old 04-09-2018, 11:59 PM   #6
Domingo
Re: 1968 c10 died
Update. Removed tank, tank was clean. Braided fuel hose was dry and falling apart, maybe it was collapsing and keeping fuel from getting to fuel pump
Old 04-10-2018, 07:29 AM   #7
Re: 1968 c10 died
First of all, these trucks don't die, they just need some health care from time to time. The line could very well be collapsing. Do you mean the short piece at the tank outlet that allows for body to chassis flex, or did someone replace the hard line to the pump with something that doesn't belong, known to result in issues on down the road? Same for pump to carb, should be hard line all the way.
Old 04-10-2018, 09:02 AM   #8
Domingo
Re: 1968 c10 died
It was about 3 feet of rubber line I'm going to replace with hard line from the tank to the pump
Old 04-10-2018, 05:27 PM   #9
El Dorado Jim
Re: 1968 c10 died
sub'd
El Dorado Jim is offline   Reply With Quote
Old 04-10-2018, 07:10 PM   #10
demian5
demian5's Avatar
Re: 1968 c10 died
Clogged vent in the tank would cause it to run for a while, be k, then not be able to suck anymore fuel as the vacuum in the tank would overcome the suction of the pump.
Loosen or pull off the gas cap and try again.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-11-2018, 09:33 PM   #11
Re: 1968 c10 died
Definitely was to get rid of that cobble job fuel line. It needs to be metal to be right and safer.
Old 04-14-2018, 11:24 PM   #12
Domingo
Re: 1968 c10 died
Im back. Removed tank replace all rubber hose with metal line tonight my son and I tried to fire it up no luck. Removed pump and behold the lever was broken what gives
Old 04-15-2018, 04:57 PM   #13
Boog
laying low
Boog's Avatar
Re: 1968 c10 died
That doesn't look like a Delco pump. Inferior parts is my guess.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-15-2018, 06:58 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 c10 died
Didn't see that earlier. I'd say it's defective. I've never seen anything like that, in many years of wrenching.
~Steven
Simi Valley, CA
Old 04-15-2018, 07:40 PM   #15
truckster
truckster's Avatar
Re: 1968 c10 died
Delco isn't what it used to be. The last AC/Delco part I bought from a dealer had "made in China" stamped on it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-15-2018, 11:37 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 c10 died
I had a '68 skylark GS that I went large with a Chevy engine, and put a 4-row truck radiator in it. I went to the Chevy dealer to get the top clamps (where better to get the part, right?) and they were made in China.
[political "rant"] China will end up owning the US as the infrastructure continues to be off-shored. [/political "rant"]
~Steven
Simi Valley, CA
Old 04-15-2018, 05:04 AM   #17
jjzepplin
jjzepplin's Avatar
Re: 1968 c10 died
Never seen that before. I use electric pumps though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-15-2018, 02:44 PM   #18
HO455
HO455's Avatar
Re: 1968 c10 died
Someone correct me if I am wrong but it may be possible to install the pump with the lever on the top of the cam if the lobe is in just the right position. I've seen this on a non Chevy engine before. Or simply just another quality part from a distant shore.
RIP Bob Parks.
Old 04-15-2018, 02:49 PM   #19
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 c10 died
You can do that on Ponchos and Fords, but the lever is too short on the Chevy pump.
~Steven
Simi Valley, CA
Old 04-15-2018, 03:02 PM   #20
HO455
HO455's Avatar
Re: 1968 c10 died
Its been awhile since highschool auto shop, too long to remember what car it happened to. I think it might have been a friends Ranchero. I do remember the lesson about it and how the oil pan had to come off the get the missing end of the lever. I must have learned the lesson well enough. I've done at least half dozen Poncho pumps over the years and never had to pull the pan. (Yet!!!)
Thanks for the information.
RIP Bob Parks.
Old 04-15-2018, 04:24 PM   #21
Hutch
Hutch's Avatar
Re: 1968 c10 died
When replacing the pump there is a bolt on the block that will hold the internal shaft in place during the installation
Last time I replaced mine there were some pumps that were really cheap that stated that they were for the non-ethanol fuel
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-15-2018, 08:02 PM   #22
Domingo
Re: 1968 c10 died
I bought the pump from summit racing. Now I'm buying another from napa auto parts. Summit racing refunded my money no question asked. They are great and will keep getting my business
Old 04-15-2018, 08:02 PM   #23
Domingo
Re: 1968 c10 died
Just now I got a bad taste of ac delco parts
Old 04-15-2018, 11:53 PM   #24
RTHarvey
Re: 1968 c10 died
A number of years ago I had a 66 corvette with a 327. When I got it, it worked OK, unless you got on it. Then about haflway thru third gear it would just die. Pull over to the side, crank for a few seconds on it was OK again. Turned out that the pivot lever for the fuel pump had fallen out. The lever then moved out of position, but only a little bit as it ran into the inside wall of the pump body. This resulted in it getting about a third of the intended stroke on the lever. So long as there wasn't much demand, it could keep up, but when you started burning some fuel it couldn't.
RTHarvey is offline   Reply With Quote
