Old 07-25-2018, 07:06 PM   #1
briand1992
Charging
So I recently did a 5.3 swap in my 80 k10 Scottsdale.... the alternator that came with the engine fits and unsure if it works. But it’s a two pin alternator(not sure what it was from). How do I hook my original 2 pin connector to the alterbator?!? I hear people are jumping the #2 wire on the rear post but what do I do with the other wire which, I believe, is for the dummy light?
briand1992 is offline   Reply With Quote
Old 07-25-2018, 07:20 PM   #2
briand1992
Re: Charging
So I actually found out is a d44 alternator from a truck which is a 250amp alternator..... the plug that came with it was cut and has an orange and brown wires and idk which one goes where. I’ve tried looking up diagrams and I couldn’t find anything that will help me
Old 07-25-2018, 07:21 PM   #3
Bandit130
Bandit130's Avatar
Re: Charging
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 07-26-2018, 02:16 PM   #4
MalibuSSwagon
Re: Charging
You don't, if you are using the GM PCM for the engine the alternator is controlled by the PCM. Your engine harness should have a connector on it for the alternator.
MalibuSSwagon is offline   Reply With Quote
Old 07-28-2018, 02:14 AM   #5
briand1992
Talking Re: Charging
Thanks malibuss. The setup I’m using is not factory fuel injection.i bought a Holley mid rise intake, Edelbrock 1406 4brl carb with electric choke and the MSD1610 ignition control module with the harnesses.
I did some tease arch, staying up all night of course, and found out that it is a self inducing alternator..... I Just don’t know what to do with that plug. I guess I’ll find out soon when its running and the battery dies LOL!
Old 07-28-2018, 02:15 AM   #6
briand1992
Thumbs up Re: Charging
Old 07-28-2018, 06:22 AM   #7
Re: Charging
Hope that means you figured it all out.
