Old 09-11-2018, 06:53 PM   #1
BigBruce2
help me Identify the transmission I got
I got this extra trans with my new purchase . I think it is a HD 400 or a 475 ? whats the going price on these same as a regular 400 ?
BigBruce2 is offline   Reply With Quote
Old 09-11-2018, 07:13 PM   #2
BigBruce2
Re: help me Identify the transmission I got
Old 09-11-2018, 08:31 PM   #3
sweetk30
sweetk30's Avatar
th400 K-case ment more for 4x4 or hd 3/4 or 1ton stuff .
and a th475 was from p-series chassis and most had bolt on e-brake on the back end . they got straight cut gears in them .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-11-2018, 08:43 PM   #4
BigBruce2
Ok so 400 k is what this one is then ?
Old 09-11-2018, 10:34 PM   #5
mikebte
Th400, mostly the same just a better housing design. Can be used in both 2 and 4 wheel applications depending on what tail you bolt on.
mikebte is offline   Reply With Quote
Old 09-12-2018, 08:15 AM   #6
GRADYS Performance
GRADYS Performance's Avatar
TH400 for a 4x4 only. And I believe it will only work with certain transfer case adapters because of the output shaft length. Output shaft is to short for a 2wd tailhousing. Price will vary depending on the purchaser. To make it 2wd the transmission would have to be taken apart and changing the output shaft and adding a tailhousing. 2wd output shafts vary if bolt on yoke or slip yoke.
GRADYS Performance is offline   Reply With Quote
Old 09-12-2018, 05:35 PM   #7
BigBruce2
So will this 400 bolt up to a 350 with an adapter and lets say a 205 transfer case without moving transaxel or transmission mounts
Old 09-12-2018, 06:22 PM   #8
sweetk30
sweetk30's Avatar
sbc and bbc use the same bell housing pattern . direct bolt up .
as to trans and t-case that combo is specific lengths each . so say you took out a th350 trans and 208 t-case this th400 might or might not drop in .
just plan on moving the trans crossemember with a few 7/16 holes drilled in the frame rail lip . then possible drive shaft length change .
as to the 205 you need the th400 to 205 adapter for the 205 you have . fig 8 or round 6 bolt pattern .
but you also need to measure the tail shaft stick out from the back of the case so you know what shaft you have for bolting fig 8 or round 6 pattern up to it .
and the 205 needs to be a 32 spline female input .
but most important does this trans work ? have you seen it drive or drove it ? all this could be for nothing if its in need of a full rebuild .
and these truck dont have a transaxle unit . thats fwd stuff .
Old 09-13-2018, 10:38 AM   #9
kwmech
1983 to 1988 turbo 400 out of a 4x with a 208 t-case. May have been behind a 6.2 diesel
