09-27-2018, 07:27 PM | #1 |
Factory th400 transmission
I’ve skimmed the posts on here about it but I was curious on whether or not a factory 400 transmission was available behind a factory 327 in a 1/2 ton pickup. Looking at one and was curious if it was possible in a 1/2 ton or if it was a 3/4 ton and up option. Gear indicator shows park R N D L1 L2. Just was curious on if possible and roughly an amount built with them. Thanks
09-27-2018, 11:56 PM | #2 |
60-66 Nut
Re: Factory th400 transmission
I've never seen a factory installed TH400 in a C10, only in the C20's. But that doesn't mean it didn't happen.
09-28-2018, 03:01 AM | #3 |
Reported here that it was a possible option. GM Heritage Center should provide an answer under vehicle kits. Will need to look 66’ with factory turbo 400, shift indicator. The one you reported, maybe for 67’ up trucks- not sure.
Les |
09-28-2018, 10:57 AM | #4 |
But Found Her 25yrs Later!
The guy here that had a factory roller cam most likely had a factory th400 in his c10.
09-28-2018, 05:35 PM | #5 |
It's Better With Nitro
I think the TH400 was introduced in model year 1964 for Cadillac and Buick, then the following year for Olds and Pontiac. I don't think the TH400s were used in trucks until the 1970s.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
09-29-2018, 01:03 AM | #6 |
60-66 Nut
I have seen a few '65-'66 C20's with TH400's from the factory. One was a '66 GMC that came from the factory with a V6 and TH400.
09-29-2018, 08:54 AM | #7 |
09-29-2018, 03:31 PM | #8 |
Moderator
09-30-2018, 06:50 PM | #9 |
1967 is the first TH400 in a C10 , not available in 66 for C10
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
