But Found Her 25yrs Later!
Re: Factory th400 transmission
The guy here that had a factory roller cam most likely had a factory th400 in his c10.
It's Better With Nitro
I think the TH400 was introduced in model year 1964 for Cadillac and Buick, then the following year for Olds and Pontiac. I don't think the TH400s were used in trucks until the 1970s.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
60-66 Nut
I have seen a few '65-'66 C20's with TH400's from the factory. One was a '66 GMC that came from the factory with a V6 and TH400.
![]() Join Date: Aug 2010
For 1966, the three speed automatic was not listed as optional equipment for C10, as it was for C20.
Yep, not in the half-ton/C10s until the '70s.
Moderator
![]() ![]() Join Date: Aug 2011
