Old 02-17-2019, 06:29 PM   #1
67 K10
1 ton 4x4 conversion
Can anyone tell me if I can convert my 1987Chevy 1 ton 2 wheel drive truck to 4 wheel drive using a 1978 drive train. I have a 3/4 ton doner.
67 K10 is offline   Reply With Quote
Old 02-17-2019, 06:32 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1 ton 4x4 conversion
it can be done but youll need a intact 4x4 donor frame..i think the 1tons came with a dana60 front
this may help.....http://www.67-72chevytrucks.com/vboa...d.php?t=546339
http://chuckschevytruckpages.com/robsK35.html
https://www.truckforum.org/threads/c...version.15456/
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-17-2019, 06:44 PM   #3
67 K10
I have a complete chassis , just wondering if the frames are the same, they look like they are, I know I have to change cross members and drill holes for spring perches.
Old 02-17-2019, 07:06 PM   #4
sweetk30
sweetk30's Avatar
c and k 30 1ton frames are bigger than 1/2 and 3/4 ton frames .
yes k30 had dana 60 front over the smaller dana 44 or corp 10 bolt axle .
the best way if you want the full k30 package is find a whole roller with good frame and driveline and swap your body over . . or find a k30 and fix it up .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-17-2019, 07:19 PM   #5
67 K10
Thanks for the response , it's a fire wood truck, so doesn't have to be perfect but 4 wheel drive would sure be nice!
Old 02-17-2019, 08:09 PM   #6
74CustomK20
74CustomK20's Avatar
Your mounts are different. Meaning 73-80 had different core support/cab mounts than your 81-87. If it's just a woods truck not end of the world. Front mounts swap between 1/2 up to 1 ton though. You'll run into crossmember clearance I think unless you got a good sized lift. Have to swap members, as the motor mounts differently though. I'd just.body swap, and maybe rear springs since you'll have it loaded a lot.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 02-17-2019, 08:45 PM   #7
SunSoaked
SunSoaked's Avatar
If you got a welder and grinder anything is possible. Depends on whether you want form or function?
SunSoaked is offline   Reply With Quote
Old 02-17-2019, 09:45 PM   #8
sweetk30
sweetk30's Avatar
73-80 = 1 style body mount
81-up = other style
and its the frame side that makes the choice of mount style .
i have a k30 frame with a c-10 body and low hump floor no body lift and th400/203-205 double t-case setup and 1 tiny dent in floor pan . and had to do custom shifter boot anyway so no problem .
Old 02-18-2019, 08:01 AM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Front frame rails above front axle are higher up on a 4x4 frame compared to 2wd.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-18-2019, 06:45 PM   #10
Honest Bob
Honest Bob's Avatar
These guys had the imho best 1 ton 4x4 conversion kits. Unfortunately they arent making them right now. You can kinda see what your in for by watching the videos on the website though.
http://cutbros.com/
Honest Bob is offline   Reply With Quote
