Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-19-2019, 12:34 PM   #1
tom7254
Auto power brake assembly
Need automatic power brake assembly (pedal) for a 1966 K20, or other year if it works. Tom
tom7254 is offline   Reply With Quote
Old 02-19-2019, 03:53 PM   #2
1960chevypanel
Re: Auto power brake assembly
Same pedal for manual and power as far as I know. The pedal pad is different, says Power Brake.
1960chevypanel is offline   Reply With Quote
Old 02-19-2019, 06:14 PM   #3
tom7254
Is the pedal pad wider or same width. If same would I just have to remove clutch pedal arm and pad?
Old 02-21-2019, 06:32 PM   #4
GMCNUT
GMCNUT's Avatar
Tom, the difference is a welded on metal piece intended to make the pedal sit lower to the floor - hence the name "low pedal" power brakes. So, the arms are and are not the same. Are in that they are cast the same as one another, but the PB one gets modified after that casting to be a PB arm. Hope that makes sense.
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 02-19-2019, 06:32 PM   #5
1960chevypanel
Same width. Not like in some vehicles where the brake pedal is wider on automatics. I would pull out the whole pedal assembly and put it on a bench, from there it's fairly easy to see how to eliminate the clutch pedal.
Old 02-19-2019, 10:08 PM   #6
tom7254
Thanks for the info. Tom
Old 02-20-2019, 08:17 PM   #7
pimpston65
pimpston65's Avatar
Did you need the “power brake” pedal? Cuz I have a few extra repops
pimpston65 is offline   Reply With Quote
Old 02-20-2019, 11:24 PM   #8
tom7254
I’ll probably remove clutch pedal and use existing brake pedal. If I go the other route I’ll contact you. Tom
Old 02-21-2019, 12:13 AM   #9
pimpston65
pimpston65's Avatar
ok
Old 02-21-2019, 11:50 PM   #10
1960chevypanel
I think Pimpston was just offering you the pad here, not the whole pedal. If you want a pad that says Power Brake on it.
Old 02-21-2019, 12:30 AM   #11
dbchevy65
Hi I’m interested in a few of your power brake pads. I pm you. Thanks
dbchevy65 is offline   Reply With Quote
Old 02-22-2019, 12:03 AM   #12
pimpston65
pimpston65's Avatar
did you want the pad or the whole assembly?
Old 02-20-2019, 01:24 AM   #13
1960chevypanel
No sweat.
