![]() Join Date: Feb 2016
66 c10 Voltmeter Conversion Final Wiring
Swapped the ammeter with a voltmeter.
One wire should be a 12 volt ignition wire under the dash?? What about the 2nd wire? |
Moderator
![]() ![]() Join Date: Aug 2011
Re: 66 c10 Voltmeter Conversion Final Wiring
We pretty much dont do anything here without pics.
Can not get a good photo
Im using the American Autowire Classic set which does not support the ammeter so i converted the ammeter to a voltmeter. Thinking to the alternator or maybe battery but not sure |
#4 | |
I'm 99% positive all you need for a voltmeter is a keyed hot and a ground. |
So a 12 volt ignition wire would work?
![]() Join Date: Sep 2002
Tapping into one of the pink wires at the back of the cluster would be the easiest.
![]() Join Date: Dec 2018
Running the positive wire to the accessories terminal on the ignition switch should work
and connecting the negative to any ground (the dash or any grounded part in side the cab) .
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
All so an accessories terminal on the fuse block would work for the 12 volts.
Active Member
![]() Join Date: Aug 2012
Like stated above, it's as easy as tapping into a pink wire on the back of the instrument cluster. From the other terminal on the voltmeter, run a wire to a clean ground anywhere close.
The pink wire is 12 volt hot with key on. I would test the voltmeter on a battery source before installing it to determine which terminal is +. |
But Found Her 25yrs Later!
Have you figured out how to post pictures? It'd be interesting to see how it looks.
