Old 12-02-2003, 08:06 PM   #1
Russell
Professional Grade
Russell's Avatar
Gotta rewire the truck, any good reference sites?
Hey guys/gals! How goes it?
Anyways, the electrical issues are starting to build up in the truck (no dome light, no underdash light, no box light, lights coming on and off in the instrumentation, stereo blown, horn fused on, no reverse lights and my cruise doesn't work) and I figure its time to get busy and rewire that thing to fix some of the hacking that my uncle did. What I need is a couple of diagrams for it, I checked that online chiltons site, but those diagrams are next to impossible to read becuase they are so badly shrunk.
Its a 1980 C2500 2WD LWB, Sierra Classic with the 5.7 L V8.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-02-2003, 08:18 PM   #2
Russell
Professional Grade
Russell's Avatar
How much does it cost?
Old 12-02-2003, 08:32 PM   #3
Russell
Professional Grade
Russell's Avatar
Hmm, 20 dollars I can afford, for some reason I thought it was more like 70...
Old 12-02-2003, 08:51 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
russell i have an oild harness that isnt cut up too bad ( just cut a few things off from it but the vast majority of it is there from the fuse block on up to the various tabs) if you want it ill box it and send ya it for shipping give me the address and ya can paypal me
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-02-2003, 08:55 PM   #5
Russell
Professional Grade
Russell's Avatar
The harness isn't too bad, its quite saveable, just that he has lots of wires that he cut too short and added on to them, without covering the connections and stuff, I just want to finish those connections properly, and clean things up a bit. Thanks for the offer though!
Old 12-03-2003, 01:39 AM   #6
Frank-id
Rewiring can be fun and easy
My claim to fame is I'm a very good electrician. Wiring new or old can be very easy. There are a few rules to follow.
Wiring can be modified many times with no effect. Wire size should not be reduced. The best connections are made with a soldering gun, solder and shrink tube. PVC tape will work on a connection but will fail after a time because of hot, cold or water. Glass fuses are the best for circuit protection but the most difficult to find the correct size when needed. The modern ata fuses are great. Even better is aircraft manual reset circuit breakers. Auto reset circuit breakers can start a good fire. Most electrical fires destroy lots of wiring. Ya cannot have too many ground connections. Some wires have smoke inside, and when not connected properly, the smoke comes out....hahahaha Disconnect the battery when making any wiring changes or repair. The number one reason for alternator failure.... poor battery post connections, next is poor grounds...
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 12-03-2003, 01:42 AM   #7
Frank-id
automatic reset circuit breaker
Also know as the fire starter.
Old 12-03-2003, 01:46 AM   #8
Russell
Professional Grade
Russell's Avatar
I'm a good electrician too, just one that likes to know what wires are what... I always use solding, with some PCV tape, don't have any shrink tube around here...
