Door Binding
My driver side door on the 67 will occasionally bind and not open past half way and I will have to partially close it and reopen it a few times before the binding stops and the door will open all the way. I do not see anything obvious wrong with the hinge that would be causing this. is this a common issue, what is the issue is it the Hinge?
![]() Join Date: Nov 2018
Re: Door Binding
I'd start with some good silicone spray lube then observe from there.
#3 | |
![]() Join Date: Apr 2017
Re: Door Binding
Also check the adjacent body panels. My passenger door binds up on the front fender, but I haven't had a chance to loosen bolts and make adjustments yet.
1968 GMC C2500 Long Bed Fleetside |
Re: Door Binding
what shape are the door stop pads and arm in? they are in the middle of the upper hinge. also, the door isnt catching the fender is it?
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
Re: Door Binding
Re: Door Binding
Check also for cracks in the door frame around the hinges.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
#7 | |
Re: Door Binding
"Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error." Is this an issue on my end? |
#8 | |
Moderator
![]() Join Date: Jun 2017
Re: Door Binding
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Re: Door Binding
I am not seeing anything too obvious. maybe one of you more experienced with the hinges can spot something.
Re: Door Binding
Any other suggestions?
Re: Door Binding
Pull the inner door panel and take a look-see to make sure something out of place is not hitting the portion that goes into the door. Make sure that same piece in not catching on the hole that it goes into. Other than that, you may have a broken pin. Willy eluded to this above.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
![]() Join Date: Jun 2007
Re: Door Binding
In post #9 in the top picture it looks like the stop pads are missing?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: Jan 2002
Re: Door Binding
Looking at the same picture it appears the slider (that goes inside the door) is hitting something evidenced by the small flat spot on the corner towards the camera. (You can see the slider missing paint where it’s contacting something.) I suggest lubing the whole hinge, hit the flattened spot with a small file to round it and see if that fixes it. I always try the easiest thing first before tearing too deep into what ever the problem is.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
Re: Door Binding
the pads for the stop arm are definitely missing and that's allowing the arm to bind. to my knowledge, the hinge must be taken apart to install new pads. I can get a picture if you need one.
#15 |
Re: Door Binding
#16 |
Re: Door Binding
not the best pictures, but here's both sides. the are steel backed pads that bind as the door opens to slow down the door as you reach the end of the arm.
#17 |
Re: Door Binding
