Old 07-21-2020, 09:51 AM   #1
kens65fb
Lokar column shift kit
I'm getting ready to install my new Flaming River steering column.
I plan to purchase the Lokar column shift kit ACA-1800
https://www.summitracing.com/parts/lok-aca-1800
When reading the reviews it seems that some C10 owners, complain that the supplied rod (21") is too short for some applications. they offer a longer (26") rod, but it only available separately for around $20.00, extra.
Has anyone installed this column shift kit ?
Any feedback would be appreciated from anyone who has actually used this kit.
kens65fb is offline   Reply With Quote
Old 07-21-2020, 10:15 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Lokar column shift kit
http://www.truckandcarshop.com/trucks60_72/t60_064.html If you go here, scroll down and look to the left, you will find they have a kit with a 23" rod. I have one but have not used it yet. I think I have the Lokar one in my other truck but not 100% sure since it has been a while since I put it in. I believe it is a lokar and it works ok.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-21-2020, 01:48 PM   #3
grubsster
grubsster's Avatar
That's what I used on my truck with a TH350. Worked just fine.
grubsster is offline   Reply With Quote
Old 07-22-2020, 12:16 AM   #4
Chevy Fleetside
I believe that is the one I used for my 700R4.
Old 07-23-2020, 08:20 PM   #5
forestb
forestb's Avatar
I had to order the longer rod for mine. If I had it to do over I would use the cable type. I only say that because I had a hard time keeping the rod from binding. With that being said the guy that installed my 700r4 got it to work vary well.
forestb is offline   Reply With Quote
Old 07-25-2020, 09:18 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
That is the kit I used as the shift linkage for my 4L80e and column shift combo. It worked perfectly in my case. The only things I did differently from what the instructions detailed was I mounted the rod end to the firewall side of the steering column selector bracket, and I machined a spacer and used a longer bolt at the transmission gear selector bracket. This helped with the angle between the two brackets in my case.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
