Old 11-22-2020, 08:09 PM   #1
Afirehawk1
396 BB Air Cleaner
Any suggestions on one that fits the best?
Afirehawk1 is offline   Reply With Quote
Old 11-22-2020, 08:28 PM   #2
geezer#99
geezer#99's Avatar
Re: 396 BB Air Cleaner
What distributor you got?
Old 11-22-2020, 10:37 PM   #3
Afirehawk1
MSD Bullet
#8361
Old 11-22-2020, 10:47 PM   #4
Captainfab
60-66 Nut
What intake manifold and what carburetor?
Old 11-22-2020, 11:20 PM   #5
Afirehawk1
Edlebrock RPM with holley 750
Old 11-23-2020, 11:03 PM   #6
Captainfab
60-66 Nut
If you use a non-dropped base, you should be able to go with a 14" diameter air cleaner. That's what I have on the 454 in my '66 Suburban with a Performer intake, 750 Holley and an HEI. The RPM intake is a little taller than the Performer, so you should have even more clearance.
Old 11-26-2020, 09:46 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
You might be able to find a 1.5" steel spacer off of a TBI 4.3L engine and use it on a drop base? Also they make carb spacers of various heights, maybe they would work?
Here's a pic from a latter model truck:
Old 11-26-2020, 11:11 PM   #8
Captainfab
60-66 Nut
I believe this is the one I bought for my '66 Suburban with the 454..........it was about 28 years ago, so it may be slightly different. Bit it is the same design I am talking about with a flat base. That way it clears the distributor with no issues. There is plenty of height under the hood for a tall air cleaner.
https://www.summitracing.com/parts/knn-60-1260
