![]() Join Date: Sep 2003
axle swap 5 bolt pattern into 67 12bolt
anyone know if the axles from 71-72 5 bolt pattern will fit/work in the 67-70 12 bolt housings? is the axle splines and length the same?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
They aren't a direct fit. They are 3/4" wider each. I think the spline count is the same. I know some board members have done this but used some kind of spacer for the extra length. I would do that personally.
I have 5 lug conversion axles for my 68. I got it from ECE. They make axles that are the right width.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
what do the ECE axles set ya back,
and I've heard early model 71 used a different width axle housing that matches the width of the 67-70's not confirmed
Rooster, I think that both ECE & Classic Perf Parts both sell 5 lug conversion axles so you might do some comparison shopping. I believe CCP's kit is axles & drums for 3 bills. I bought better axles from Moser & got drums for a 72 @ Autozone.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Rooster, you're close.
It's the 70s that can go either way. There was a running change during production to wider axles. The later axles will fit in the early housings, but like was said, they are too long by 3/4 inch. What some guys are doing is fabricating a 3/4 inch spacer that goes between the axle housing flange and the brake backing plate. Then bolt the backing plate on with long bolts. This effectively moves the brakes out 3/4 inch to line up with the longer axles.
Nah I'll use the correct length stuff.
they were engineered for the load rating with the flange, and wheel contact in a specific place, ya know. and I have been known to haul stuff around.
