![]() Join Date: Jul 2008
How to remove GMC cab/door trim
Hey guys, do I found this GMC Custom in a junkyard and I want to buy the trim. I will have to remove it and I’m sure it’s rusty and stubborn as can be. I have never removed this kind of trim before and looking for some insight on how to remove the entire set and any tips you guys might be able to give.
1965 c/10 swb 1969 c/10 lwb ![]() |
Re: How to remove GMC cab/door trim
It is held on by what I call spring clips on the backside, a trim removal tool would work. Guy removes a piece in the video below, but they do have the inner panel out which makes it easier to get to the backside.
https://youtu.be/tOWZWyB24LU?t=2580
1964 GMC Fleetside SWB 1966 Mustang Coupe 2013 Tahoe LT Last edited by 1slo64; 03-16-2021 at 02:22 AM. |
#3 | |
The rust on the clips will give it some grip in the hole. A little spray lube sprayed under the trim at the clip will help. I would buy a cheap putty knife and cut a slot in the middle so the slot can go around the clip and pry carefully. I've seen that gmc trim sell for $200 per side. Can you see ANY of the clips from behind? If so push from behind like the video.
#5 | |
That’s crazy! I’m mostly getting this stuff to use as trade material. I’ll give that a try! I’m an hour away from the truck and I didn’t have a ton of time to inspect the clips and mounting hardware the first time I was out there. Planning to go back Friday.
Yeah I've seen the trim for sale that high as well. I got lucky and paid $200 for all of mine.
Also forgot to mention they should be bolted to the door in a couple spots.
1964 GMC Fleetside SWB 1966 Mustang Coupe 2013 Tahoe LT Last edited by 1slo64; 03-16-2021 at 04:06 PM. |
Take that seat.
That’s the plan... well if I can get it out I will. It’ll most likely have to go out through the windshield
I never knew GMC made a custom. Cool
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
