Old 03-16-2021, 01:37 AM   #1
chev-obsession
chev-obsession's Avatar
How to remove GMC cab/door trim
Hey guys, do I found this GMC Custom in a junkyard and I want to buy the trim. I will have to remove it and I’m sure it’s rusty and stubborn as can be. I have never removed this kind of trim before and looking for some insight on how to remove the entire set and any tips you guys might be able to give.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 03-16-2021, 02:13 AM   #2
1slo64
Re: How to remove GMC cab/door trim
It is held on by what I call spring clips on the backside, a trim removal tool would work. Guy removes a piece in the video below, but they do have the inner panel out which makes it easier to get to the backside.
https://youtu.be/tOWZWyB24LU?t=2580
1964 GMC Fleetside SWB
1966 Mustang Coupe
2013 Tahoe LT
1slo64 is offline   Reply With Quote
Old 03-16-2021, 10:11 AM   #3
chev-obsession
This look like a pain to remove. Is there any trick to getting those trim pieces off with the inner panel in place?
1965 c/10 swb
1969 c/10 lwb
Old 03-16-2021, 02:47 PM   #4
bigmoe
bigmoe's Avatar
The rust on the clips will give it some grip in the hole. A little spray lube sprayed under the trim at the clip will help. I would buy a cheap putty knife and cut a slot in the middle so the slot can go around the clip and pry carefully. I've seen that gmc trim sell for $200 per side. Can you see ANY of the clips from behind? If so push from behind like the video.
bigmoe is offline   Reply With Quote
Old 03-16-2021, 03:09 PM   #5
chev-obsession
That’s crazy! I’m mostly getting this stuff to use as trade material.
I’ll give that a try! I’m an hour away from the truck and I didn’t have a ton of time to inspect the clips and mounting hardware the first time I was out there. Planning to go back Friday.
1965 c/10 swb
1969 c/10 lwb
Old 03-16-2021, 03:54 PM   #6
1slo64
Yeah I've seen the trim for sale that high as well. I got lucky and paid $200 for all of mine.
Also forgot to mention they should be bolted to the door in a couple spots.
1966 Mustang Coupe
2013 Tahoe LT
Old 03-17-2021, 12:25 PM   #7
Joemomma1
Joemomma1's Avatar
Take that seat.
Joemomma1 is offline   Reply With Quote
Old 03-17-2021, 01:23 PM   #8
chev-obsession
Originally Posted by Joemomma1 View Post
Take that seat.
That’s the plan... well if I can get it out I will. It’ll most likely have to go out through the windshield
1965 c/10 swb
1969 c/10 lwb
Old 03-20-2021, 09:39 PM   #9
karlbenz
I never knew GMC made a custom. Cool
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
