Old 11-07-2021, 01:20 PM   #1
Bandit130
Bandit130's Avatar
Rear cab wall thickness
Is the rear cab wall below window a double wall? If so, does anyone know how thick it is?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 11-08-2021, 10:23 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Rear cab wall thickness
Quote: Is the rear cab wall below window a double wall? If so, does anyone know how thick it is?
Yes the rear cab wall is double walled. For two reasons heat from exhaust heat and cut down on road noise
& reverb. Not to sure but you should be able to see near the bottom out side edge,
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-10-2021, 01:02 PM   #3
Big Chip
Big Chip's Avatar
It's only double walled to just below the window. I would say there's approximately 1/2" between the layers. I think if you get a mirror in the corner and look up you will see how much room there is.
Big Chip is offline   Reply With Quote
