![]() Join Date: Feb 2016
US Mags Indy wheel fitment
Having searched to no avail as to whether the new classic slotted U.S. Mags Indy U101 wheels will fit a 71-72 disk brake front end.
My Burban has been converted to 5 lug with 71-72 front end components and a rear axle. I am planning on the 15x8 wheels with 4 inch backspacing. My current wheels are only 3.5" backspacing Any help would be appreciated. I am hoping someone can confirm them clearing the brakes so I can order all 4 at once instead of just one to test clearance. I should have done this post 2 weeks ago as I see the prices have jumped $13 a wheel since then. DHOOO! ![]() https://www.summitracing.com/parts/usm-u10115807340
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
BlahBlahBlah
Re: US Mags Indy wheel fitment
Those will look so good on your burb. I hope they work out for ya.
#3 | |
#4 | |
My current wheels that fit with a 3.5" backspacing, very likely would rub the tie rod with a 4" backspacing. Unfortunately none of the currently available 15" slotted mags come in a 3.5" backspacing. I was hoping that I might avoid some shipping return hassles by posing the question here first. Thanks CG!
#5 | |
Fit is perfect on my 72 K20 disc brake front end....if that is any help?
#7 | |
Great looking truck by the way!
#8 | |
All about them K’s
![]() Join Date: Jun 2014
Love yours!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
BlahBlahBlah
I think I have a set of five lug and a set of six lug mags put away somewhere with our trucks bolt patterns. But I would rather have a new set.
I'm feeling the need for new ones too! After the ordeal I had getting one of the current wheels repaired after the wreck, being able to order a new replacement if needed sounds like a great idea.
As a follow up I got the wheels and they fit great.
Even with the back spacing difference there is slightly more room between the tie rod end and the wheels outer edge compared to the old wheels. Wheel weights need to be placed carefully so the won't contact the brake caliper. The rear axle hub is a very close fit (Hub centric) and any deformity or build up of rust will prevent the wheel from fitting correctly.
BlahBlahBlah
Wow, those look great!
laying low
![]() Join Date: Mar 2001
It looks good. I'm mostly glad you went with 15". It just looks right!
Thanks everyone. I appreciate it.
#15 |
Do you think 15x10s 4 inch back spacing would fit?
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
#16 |
I can take some pictures and get some measurements for you.
My 67 Suburban has the wider 71-72 12 bolt rear end in it. You will need to take that into consideration if you have a different rear end.
