![]() ![]() Join Date: Feb 2009
Thermostat Housing Switch
Just curious if anyone still has the complete assembly, and if you do props, does it work
![]() Looks like this, perhaps
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-26-2023 at 09:52 PM. |
Re: Thermostat Housing Switch
I believe that's off a newer engine ... probably mid/late 70's or 80's ... not original for 67-72.
Those thermal vacuum switches (TVS) were used to control a variety of things ... like EGR valves and other emissions equipment. |
#3 | |
![]() Join Date: Mar 2003
Sometimes even the vacuum advance on the dist. |
#4 | |
Might be worth mentioning the housing I removed from my 1971 is cast iron, stamped 1595. It's vintage IMO, though I'm not sure it's truck original, and it doesn't have female threads for a switch.
#5 | |
In fact, GM did that from the factory (pipe plug in that hole) on mid/late 70's trucks that were over the GVW threshold to be considered "heavy duty" and didn't require as much emissions equipment as cars & lower GVW trucks. |
#6 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I can't say with 100% certainty, but I don't think 72 & earlier thermostat housings originally had that female threaded hole in them. I've seen both iron and aluminum versions of the housings without the hole ... I don't know if that was something that changed after a certain year or if it varied by application.
I use one of those to control one of the electric pusher fans. The switch is a 208* switch from a Honda Accord. I had to make the thread adapter. The other fan is controlled by the AC. Both fans are from '90s Cadillacs.
'67 GMC 2500, 292, 4spd, AC |
![]() ![]() Join Date: Jul 2002
My 81's 250 6 had that. Mostly for smog stuff. I think I still have them. I've seen them use the thermostat housing for a seperate temp sensor for electric fans.
Ibelive the 6 stuff will work on small block also.
That is a newer housing. 67-72s didn't have that stuff. A story: I used to stop in the my Chevy dealer on a regular basis to have the parts guy look up parts availability and order what was available. One day I had him check 69-72 truck steering wheels. "It shows they are available but only in black". I couldn't get the words "Order me up one" out of my mouth fast enough. It came in as the current '80s truck steering wheel. That's when I learned GM's concern for supplying parts for their vehicles is offering what will work, not what is correct for a restoration. They print supplemental parts books to list superceded parts numbers for depleted parts numbers
Thanks for the education
I forget or never knew. Original housings have a hole for a spring I guess, what for?
Who Changed This?
![]() Join Date: Jan 2013
That was for the throttle return spring on a lot of vehicles.
I really like those housings with the tab & hole for return spring. I keep those when I find them
At the body shop.
Some opened/closed the hot air stove door in the air cleaner.
" That didnt make it any newer " " Dont antique the equipment " |
