Old 01-26-2023, 07:10 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thermostat Housing Switch
Just curious if anyone still has the complete assembly, and if you do props, does it work. I may never assemble one, but I'm wondering, what do the lines route to? Thanks.
Looks like this, perhaps
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-26-2023, 07:48 PM   #2
ray_mcavoy
Re: Thermostat Housing Switch
I believe that's off a newer engine ... probably mid/late 70's or 80's ... not original for 67-72.
Those thermal vacuum switches (TVS) were used to control a variety of things ... like EGR valves and other emissions equipment.
ray_mcavoy is offline   Reply With Quote
Old 01-26-2023, 07:57 PM   #3
kwmech
Sometimes even the vacuum advance on the dist.
Old 01-26-2023, 09:17 PM   #4
71CHEVYSHORTBED402
Pretty sure that housing is 336790, which shows for a number of truck years, including 71-72. But the switch might be different.
Might be worth mentioning the housing I removed from my 1971 is cast iron, stamped 1595. It's vintage IMO, though I'm not sure it's truck original, and it doesn't have female threads for a switch.
Tony
Old 01-26-2023, 11:42 PM   #5
ray_mcavoy
Yes, the GM parts catalogs could very well list that newer style thermostat housing as a service replacement part for earlier years. The installer would simply have to put a pipe plug in the unused hole.
In fact, GM did that from the factory (pipe plug in that hole) on mid/late 70's trucks that were over the GVW threshold to be considered "heavy duty" and didn't require as much emissions equipment as cars & lower GVW trucks.
Old 01-27-2023, 01:30 AM   #6
71CHEVYSHORTBED402
I see. I searched 336790, and it comes up on vehicles from 1966 to 1979. Are you saying 67-72 came without female threads? As I mentioned earlier, the cast iron pulled from my truck was without threads.
Tony
Old 01-27-2023, 05:43 PM   #7
ray_mcavoy
I can't say with 100% certainty, but I don't think 72 & earlier thermostat housings originally had that female threaded hole in them. I've seen both iron and aluminum versions of the housings without the hole ... I don't know if that was something that changed after a certain year or if it varied by application.
Old 01-27-2023, 06:41 PM   #8
leftybass209
leftybass209's Avatar
The 350/350 in my 72 had the original intake, water neck, and quadrajet, and was an A/C and CA emissions born truck, but no extra provisions in the cast iron water neck.
I only lend the extra info because as we've found out on these trucks before... sometimes it's just a goofy combination of parts ordered that requires different parts like this.
leftybass209 is offline   Reply With Quote
Old 01-29-2023, 02:18 PM   #9
RichardJ
I use one of those to control one of the electric pusher fans. The switch is a 208* switch from a Honda Accord. I had to make the thread adapter. The other fan is controlled by the AC. Both fans are from '90s Cadillacs.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-29-2023, 06:22 PM   #10
My 81's 250 6 had that. Mostly for smog stuff. I think I still have them. I've seen them use the thermostat housing for a seperate temp sensor for electric fans.
Ibelive the 6 stuff will work on small block also.
Old 01-30-2023, 08:48 AM   #11
That is a newer housing. 67-72s didn't have that stuff. A story: I used to stop in the my Chevy dealer on a regular basis to have the parts guy look up parts availability and order what was available. One day I had him check 69-72 truck steering wheels. "It shows they are available but only in black". I couldn't get the words "Order me up one" out of my mouth fast enough. It came in as the current '80s truck steering wheel. That's when I learned GM's concern for supplying parts for their vehicles is offering what will work, not what is correct for a restoration. They print supplemental parts books to list superceded parts numbers for depleted parts numbers
Old 02-05-2023, 08:31 PM   #12
71CHEVYSHORTBED402
Thanks for the education
I forget or never knew. Original housings have a hole for a spring I guess, what for?
Tony
Old 02-05-2023, 09:03 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
That was for the throttle return spring on a lot of vehicles.
~Steven
Simi Valley, CA
Old 02-06-2023, 07:52 AM   #14
I really like those housings with the tab & hole for return spring. I keep those when I find them
Old 02-06-2023, 12:52 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Some opened/closed the hot air stove door in the air cleaner.
KQQL IT is online now   Reply With Quote
