Old 03-25-2023, 07:40 PM   #1
Too Slow '90
Too Slow '90's Avatar
Transmission Hump Height
Is the trans hump pictured low or high? I have a base '60 Apache with a three speed manual. I thought they came with the low hump but the rubber mat I just bought is too small so it has me thinking....
Too Slow '90 is offline   Reply With Quote
Old 03-25-2023, 08:39 PM   #2
Arne
Arne's Avatar
Re: Transmission Hump Height
That looks considerably taller than mine, which I believe is a low hump.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 03-25-2023, 09:15 PM   #3
FamilyTruckster65
You are both showing pictures of a high hump. Normally the high hump is bolted in and a low hump generally is welded in.
FamilyTruckster65 is offline   Reply With Quote
Old 03-25-2023, 09:18 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
Both of y'all have a high hump. The low hump has a step up at the rear.
The low hump was bolted in on 60-63 floors.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-26-2023, 06:44 AM   #5
Too Slow '90
Thanks to all who responded. So is it normal to have a 3 speed manual and a high hump on a '60? From what I read it should be a low hump from the factory. This is a one owner (family) vehicle that I don't believe has ever been modified before it came to me.
Old 03-26-2023, 09:40 AM   #6
cwcarpenter98
I'm not sure on that, but it's definitely plausible. The front section of the tunnel different between high and low, so if it's been changed in the past, you probably would be able to tell
Christian Carpenter
Old 03-26-2023, 08:10 PM   #7
62c30
I have a 61 half ton with a 3 on the tree and a 62 one ton with the factory four speed. Other than the hole for the shifter on the one ton they are the same and both bolt in.
62c30 is offline   Reply With Quote
