![]() Join Date: Aug 2008
WTB early Corvette rocker covers,road draft tube, ram horn manifolds, aluminum intake
I recently picked up a rebuilt 283 for my 57 NAPCO. It currently has the stock stamped steel valve covers, a cast iron 2 barrel intake and carb. No exhaust manifolds. I am also missing the road draft tube the bolts to the block by the distributor. If anyone has a reasonably priced set of “staggered” corvette rocker covers, stock type “rams horn” exhaust manifolds and period style aluminum intake like an Edelbrock C3B/ C3BX intake with the oil filler tube provision, please advise cost and total price shipped to Leander Tx 78641.
![]() Join Date: Nov 2008
Re: WTB early Corvette rocker covers,road draft tube, ram horn manifolds, aluminum in
Some parts that I have
![]() Join Date: Jul 2001
Will look in the parts shed, thinking I have a April '57 283 4 BBL cast iron intake and a driver's side 283 '57 exhaust manifold if you would have a possible interest in either for your '57 NAPCO. Will look tomorrow and let you know for sure.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
![]() Join Date: Mar 2022
I don't know if this is the draft tube that you are looking for. It's "G" on this posting.
https://67-72chevytrucks.com/vboard/...d.php?t=847312
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
Not mine - found pic on interweb - but here is what you need for a stock road draft tube. Top part is under the intake and the other goes in the hole in the block using the bolt shown. I am not 100% sure if the actual hose is formed or not.
I didn’t get notifications that I had replys…
Wideside72, sorry I totally spaced getting back with you in regards to the '57 4BBL intake and the driver's side exhaust manifold. If still in need of either let me know and will look in the parts stash. Have done two swap meets since my last posting with you, need to check and verify if I have either, both or none of those parts still.
| Bookmarks |
