Tilt column lower bearing
Hey guys I recently tore apart my junkyard van tilt and modified it to work in my truck along with regreasing and freshening it up but have hit a snag. What I thought would have been a non issue on disassembly turned into my only major hang up on reassembly. I cannot figure out what I'm doing wrong putting the lower bearing assembly back in. I have tried what seems like every combination of assembling the bearing and retainer and nothing seems to work. By what I can tell it has to go in the order of plastic retainer then bearing and finally the little metal cap. Can somebody help me out on what I'm missing?
![]() ![]() Join Date: Jan 2005
Re: Tilt column lower bearing
A clip like this holds the metal cap in place
Sorry, I should have been more specific. I've got the little clip and cap they just aren't on in the picture. The hole in the center of the cap is big enough the bearing can just fall right through the middle. What keeps the bearing from just sliding through the cap?
![]() Join Date: Oct 2006
The bearing has a rounded shoulder that slips into a recess in the white nylon piece. That interference holds the bearing in place. Sometimes it's difficult to drive the bearing into the white part, but if you have something long enough to slip over the steering shaft and contact the inner bearing race, you can drive it in.
#5 | |
![]() Join Date: Apr 2010
Hhhmmm, on the 72 tilt the bearing looks like it is inside the tube and the plastic retainer is outside. Sorry this is the only service manual I have for tilt. Looks like changes were made on later columns?
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
![]() Join Date: Feb 2016
I don't know if these pictures help or not. They're of the lower end of a 72 firebird tilt column. The same but different.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
