Old 12-18-2023, 10:20 AM   #4
29od1
Re: Tilt column lower bearing
The bearing has a rounded shoulder that slips into a recess in the white nylon piece. That interference holds the bearing in place. Sometimes it's difficult to drive the bearing into the white part, but if you have something long enough to slip over the steering shaft and contact the inner bearing race, you can drive it in.
29od1 is offline   Reply With Quote
