11-23-2024, 11:51 AM | #1 |
landarts
Help with woodgrain matching
I have a build thread I am doing over in the 4x4 section here. It is a 72 Super Cheyenne K20 4x4 truck. The friend I am building for "Bestview" purchased an NOS aluminum woodgrain panel from DeadheadNM a few years back for this project. I finally got the glove box all stripped down and re-painted and set the woodgrain pane on top to see how it looks. Then I purchased a new woodgrain gauge bezel. They are not even close in woodgrain color or style.
So the question is, is there a 3M vinyl that others have used that will match closely to the glove box pattern? I have an accurate CAD file of the gauge bezel and I own a full-size CNC router machine that has a tangential cutter that I can cut the vinyl to the exact size and install. I also have to recover the woodgrain door panel inserts to match. Any help on this is really appreciated. Photo 1 - freshly painted glove box with NOS woodgrain insert Photo 2 - comparison of the bezel and the glove box panel
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
11-23-2024, 10:42 PM | #2 |
Re: Help with woodgrain matching
That is a very real problem when restoring a super. I would love to find a source for accurate woodgrain vinyl. I think there is a real market for it too
11-24-2024, 06:04 PM | #3 |
I had the same issue when I ordered a new aluminum applique. I personally prefer the woodgrain pattern as shown on your bezel versus the larger and lighter grain of the original pattern. So I ended up applying a new decal to my new applique. End result took me three decals to get it applied with minimal bubbles. If I did it again, I would probably take it to a sign shop to have them apply it. All I had was a heat gun to get the bubbles out, and the first trial ended up shrinking an area that I couldn't make right again. I found the first one at Holley.com and the subsequent ones at classicparts.com. They are the same part, just a little cheaper at classicparts. These are the oversized ones for no trim panel, and that gives a little extra meat on the edges for trimming.
With that said, I do recall seeing a part number in a past search for the original vinyl that was close. It will take a little digging, but there was one somewhere in these forums.
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" Last edited by 1972CheyenneSuper; 11-24-2024 at 06:12 PM. |
11-24-2024, 06:14 PM | #4 |
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
11-25-2024, 06:54 PM | #5 |
Any one else has info
11-26-2024, 09:10 PM | #6 |
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-27-2024, 09:00 AM | #7 |
Here is a purported Super survivor:
Purported 19k mile original: Another survivor:
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-27-2024, 02:54 PM | #8 |
These are all originals.
12-01-2024, 04:26 PM | #9 | |
A couple of more threads I found searching for 3M DI-NOC https://www.67-72chevytrucks.com/vbo....php?p=3605416 https://www.67-72chevytrucks.com/vbo...d.php?t=660030 https://www.67-72chevytrucks.com/vbo...d.php?t=691825 https://www.67-72chevytrucks.com/vbo....php?p=7460435 And well, I found the op's build thread: https://www.67-72chevytrucks.com/vbo....php?p=9355810 Off to scroll through that.
11-25-2024, 07:07 PM | #10 |
Could just stain some oak veneer in a Walnut shade
1970 C10 Custom longbed 350/350 |
11-25-2024, 07:25 PM | #11 |
Good information
12-05-2024, 11:51 PM | #12 |
Carpe manana
To clarify, the piece shown above isn’t NOS GM it is a NORS if you will from Golden State Pickup parts and was sold as such. I was going to use this but happened upon a GM piece. I’ll dig for a photo of the NOS piece that I’ve since installed.
EDIT: Added photos. The top photo shows the NOS GM piece against the Golden State piece, which has pre-punched holes for the emblem. I’ve got NORS Golden State 1) woodgrain 72 door inserts on my K20 and 2) tailgate band on the Blazer. These were US made pieces. The bottom photo is a NOS cluster bezel I recently added to the K20. If anyone is interested in the Cheyenne Superman glove box door (black) and woodgrain bezel I removed from the K20 I can post these up to the parts board.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-06-2024 at 12:15 AM. Reason: Added |
