Old Yesterday, 08:36 PM   #1
IT Cowboy
Junior Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Recommend me a LED light kit
Is there a recombed LED light kit for the all the marker and tail lights that is quality and bright and that will last, oh and that is pretty much plug and play?
I would like brighter tail lights especially becuse other drivers around here SUCK lol
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old Yesterday, 11:02 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Recommend me a LED light kit
You might look into a headlight relay kit first. I put one on my truck and it made a huge difference. The headlight current doesn't go through the switch, so there's a lot less voltage drop, and all the other lights are brighter, as a result. Check it out-
https://67-72chevytrucks.com/vboard/...d.php?t=782071
As for brighter brake lights, unless you have flamethrowers, people are gonna be stupid behind you, anyway. People tailgate the H*** out of me, even when I'm speeding. I guess they like the fumes?
~Steven
Simi Valley, CA
Old Today, 12:08 AM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
Originally Posted by Steeveedee View Post
.... People tailgate the H*** out of me, even when I'm speeding. I guess they like the fumes?
I always told my kids nobody tailgates a 70's car, but there's no accounting for personal preference ;-)
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old Yesterday, 11:13 PM   #4
67ChevroletDude
67ChevroletDude's Avatar
I recommend the headlight relay as above concerning your headlights. As for all the other lights, I really like the quality of the United Pacific branded lights and run their front marker lights myself and have helped friends install them everywhere else. I went through just about every ebay/amazon LED bulb there was before finally going that way. Just make sure you get LED flashers with the ground wire or else you'll quickly find your blinkers and hazards don't work.
67ChevroletDude is offline   Reply With Quote
Old Today, 12:10 AM   #5
IT Cowboy
Junior Member
IT Cowboy's Avatar
Damn, this site costs me more money and time every time I ask a question ��
Old Today, 02:11 AM   #6
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
That's not quite true. They told you on another thread not to buy an aluminum radiator & dual fans for your 402.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old Today, 01:36 AM   #7
Richard
Believe you have a 72. Note that problems will occur with front turn/running and side marker lights with led bulbs installed. ie- no lights or flashing. It has to do with how the side markers are grounded through the front turn bulbs. Side markers alternate flash with front turn on 71/72 trucks. Wiring changes and relays or diodes may be implemented to make led's work. Easiest solution for folks that want led is to direct ground the side front markers and eliminate the side flashing like the 69/70 trucks.
Richard
