Old 02-10-2025, 08:34 AM   #1
IT Cowboy
IT Cowboy's Avatar
Were three point seatbelts part of a package?
My Highlander truck has holes in the B pillars for seatbelts but there are none there and I only have lap belts. Were the three point belts part of a package or did they put the mounting holes for them in all trucks
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-10-2025, 08:44 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Were three point seatbelts part of a package?
They were a VERY rare option on these trucks. RPO code A85. Not a part of a package. Stand alone option. Could get them front and rear on Blazers and Suburbans too.
Old 02-10-2025, 08:51 AM   #3
IT Cowboy
IT Cowboy's Avatar
I have a "1B8530 - Belt Molding" listed on the glovebox sheet.
Old 02-10-2025, 09:10 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Belt molding refers to upper and/or lower trim on the exterior of the truck. Shoulder belts were a stand alone option but were not 3 point. They were separate harnesses and a pain in the butt to use so the option was not often ordered.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-10-2025, 09:35 AM   #5
TKCR
TKCR's Avatar
All the trucks came with the holes already in the pillar, that even included the 1973-1975 square body trucks, which were also 2pt lap belts. You could order 3pts. It wasn’t until 1976 that 3pts were installed in all the trucks.
Old 02-10-2025, 09:41 AM   #6
Rich69shortfleet
Yes, because the shoulder belt did not have a retract feature so it was hard to lean forward with the belt on if it was adjusted correctly.
Rich69shortfleet is offline   Reply With Quote
Old 02-10-2025, 10:52 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Yep, just a vertical lap belt. I added them to my truck but never used them for that reason
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-10-2025, 10:12 AM   #8
IT Cowboy
IT Cowboy's Avatar
As I posted, my truck has holes for the shoulder belts so I wondered if someone added them and then someone else removed them to return it to the original or it the belts were originally there at one time I haven't looked close but it looks like the holes in the pillar were stamped in as they have a small notch to them and do not look drilled recent meaning they were painted over when the repaint was done on the truck.
Old 02-10-2025, 10:20 AM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
All of the trucks have those holes. They usually have a plastic plug covering them up.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-10-2025, 10:22 AM   #10
IT Cowboy
IT Cowboy's Avatar
Ahh, that makes more sense then and that is what I was wondering.
