Help with a Bracket
Hey
took this bracket off and cannot remember it went pretty sure it was under the dash on drivers side, but im not sure usually good at pictures, but this one i did not pictures would help if you have them Thank,s for any help
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
Re: Help with a Bracket
Is this the bracket that mounts between the dash and the A pillar, holds the dash in place? I didn't remove my dash but it looks kinda familiar. Has the curvature of the dash. Just a guess
The inner fender bolt to this, near the top of the firewall ( under the dash). It's common for them to fall off.
1951 Truck, LS1/4L60 1964 Suburban, current project |
Ok
Thanks for the replies and Yes it is the support on the inside for the inner fender on the Drivers side Got another Question, is there supposed a similar bracket under the dash on the Passenger side or is it supported by something else if i cant find one, im sure i could make one out of flat steel that would work Thank,s
You should have the same style for the Pass side.
| Bookmarks |
