Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
I recently changed the trans fluid in the TH400 of my 1968 C10 shortbed fleetside and now it wants to slip and not get into gear. I feared this was going to happen. I decided to fix a trans pan gasket leak and changed the fluid in the process. The trans has alot of miles on it and most likely needs rebuilt but I was hoping to get some more cruising in before swapping my factory 396/TH400 for a 454/4L80E combo. So that I could rebuild my original drivetrain and set it aside if I wanted to return it to factory specs in the future.
Any suggestions about my TH400. |
Re: Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
Just checking, but you didn't put synthetic fluid in it by chance? That would definitely make it slip.
#4 | |
![]() Join Date: Dec 2009
Any transmission fluid has the characteristic of being able to clean out varnish and particles in a transmission. On older transmissions it's more pronounced. That's why it was used to " clean" lifters in noisy valve trains. When you change over to new fluid it will flush out or loosen that varnish or debris. The particles loosened when the new fluid circulates can jam up the operation of valves and pistons . This will cause shifting problems. Time for a rebuild and proper periodic servicing in the future. Synthetic transmission fluid is not your problem. That may have been a cause for engine seal leaks back through the mid 90's but how it became a transmission problem currently is unclear. |
20' Daredevil (Ret)
![]() Join Date: May 2003
No clue if this might apply to your TH400 -- my TH350 acts exactly as you describe if it is low on fluid.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Good suggestions. You do want Dextron III not VI. Needs to be full warm running in neutral on flat ground. Back in the day we used to put some type F fluid in to make them shift a little harder. Might try that if all else fails. Is it possible that the filter is not on fully?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Jun 2022
Everyone's on this, but how much fluid did you put in vs the rated capacity?
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Is it sucking air maybe (filter not tight or similar)
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
Low on fluid. Needs to be filled while running.
I did not fill it while running. I put in 4 quarts of fluid. When it wouldnt move after I started it up and let it run for about 3 minutes or so I shut it off and just left it parked in my garage and havent tried again since.
20' Daredevil (Ret)
You got good advice above. To check for correct fluid level, park on a level surface, engine warmed up & idling, trans in neutral (actually, Park is OK too). Otherwise you are just guessing.
Likely low on fluid. Depending on pan could be 4-8 qts. If you can't see any on the stick on level ground and cold you don't have enough yet. I'd think at least 5 if not 6 qts.
How did the old fluid look? If I am looking at a filter in a transmission, I'm going to change it except in some very rare set of circumstances.
#15 | |
I will double check the fluid this weekend with it running. I will need to find a good cork gasket instead. |
#16 |
Drop the pan and make sure the filter is properly attached to the trans.
Something happened there, theres no other answer... |
#17 |
![]() Join Date: Jun 2005
The other answer is that it is low on fluid. There is going to be more than 4 QTs of fluid that comes out. It will likely take 9-10 QTs. Remember, fluid drains out of the trans back into the pan when the pump is not turning. Just because the pan only holds 4 QTs of fluid does not mean that that is all that is in the trans.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#18 |
On another note, Type F will not hurt the trans, it will cause firmer shifts. The issue is, you didn’t drain the torque converter, so if you had dexron in it before they are now mixed, AND, you now have old dexron mixed with new Type F, which kind of defeats the purpose of changing the fluid. The torque converter holds a few QTs of fluid. I would start it up on level ground let it warm up and add fluid until you see it at the full mark on the dipstick, I think you will find it cures your issue.
#19 | |
#20 |
Does Dexron mix with Type F ?
#21 |
Shouldn’t cause any issues, but I wouldn’t do it deliberately and only short term.
#22 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
B&M Trick Shift was about the same as Type F except it was dyed blue. I ran it for years in my hot rods after putting in shift kits. Don't know if it is still blue; it's been awhile.
#23 |
Well I got the trans pan sealed tight with zero leaks. I started the truck and put in 5 quarts while it was in neutral. I let the truck warm up and made sure the dipstick was reading at the full mark.
Truck still doesnt move. I shifted through all of the gears and nothing. The trans is original to the truck and has ALOT of miles on it. i cant think of anything else to check. I guess it need to be rebuilt. Instead of rebuilding it though I might just get a rebuilt 4L80E instead and just put the TH400 in storage. I am bummed out though as I was hoping to cruise it around some more this summer. |
#24 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
I would have sworn it was green.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced) 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold) 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced) 73 El Camino SS 454 4 speed my first big block Can you tell we are fans of longbed fleetsides & 67s Chris |
#25 |
All about them K’s
![]() Join Date: Jun 2014
Dex 6 won’t hurt it. All this anti synthetic bs is amusing. Dex 6 is so far superior in every way to dex 3 and its reverse compatible meaning when the converter is still full of 3 you can safely run 6 on fluid and filter change. I run it in all my old automatics. It’s far more resistant to heat, the viscosity is more consistent, and it doesn’t foam near as much as 3. Sorry had to vent lol, I see these kinds of posts on some of the other boards I’m on and it drives me nuts how some of these opinions and understandings are skewed.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
| Bookmarks |
