Old 03-18-2026, 12:14 AM   #1
HeavyHauler
Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
I recently changed the trans fluid in the TH400 of my 1968 C10 shortbed fleetside and now it wants to slip and not get into gear. I feared this was going to happen. I decided to fix a trans pan gasket leak and changed the fluid in the process. The trans has alot of miles on it and most likely needs rebuilt but I was hoping to get some more cruising in before swapping my factory 396/TH400 for a 454/4L80E combo. So that I could rebuild my original drivetrain and set it aside if I wanted to return it to factory specs in the future.
Any suggestions about my TH400.
HeavyHauler is offline   Reply With Quote
Old 03-18-2026, 07:34 AM   #2
Joyridin
Re: Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
Just checking, but you didn't put synthetic fluid in it by chance? That would definitely make it slip.
Joyridin is offline   Reply With Quote
Old 03-18-2026, 09:08 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No clue if this might apply to your TH400 -- my TH350 acts exactly as you describe if it is low on fluid.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 03-18-2026, 11:16 AM   #4
MARKDTN
Good suggestions. You do want Dextron III not VI. Needs to be full warm running in neutral on flat ground. Back in the day we used to put some type F fluid in to make them shift a little harder. Might try that if all else fails. Is it possible that the filter is not on fully?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-18-2026, 01:06 PM   #5
Rust_never_sleeps
Rust_never_sleeps's Avatar
Everyone's on this, but how much fluid did you put in vs the rated capacity?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 03-18-2026, 01:08 PM   #6
Shifty One
Shifty One's Avatar
Is it sucking air maybe (filter not tight or similar)
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-18-2026, 08:24 PM   #7
BDC90
Low on fluid. Needs to be filled while running.
BDC90 is offline   Reply With Quote
Old 03-18-2026, 09:13 PM   #8
HeavyHauler
Definitely not. I put in Type F. Thanks for asking as that is a good question.
Old 03-18-2026, 09:14 PM   #9
HeavyHauler
I did not mess with the filter.
Old 03-18-2026, 09:20 PM   #10
HeavyHauler
I did not fill it while running. I put in 4 quarts of fluid. When it wouldnt move after I started it up and let it run for about 3 minutes or so I shut it off and just left it parked in my garage and havent tried again since.
Old 03-18-2026, 09:24 PM   #11
HeavyHauler
I put in 4 quarts of fluid. The only thing I did was drain and remove the trans pan to replace the trans pan gasket because it was leaking.
Old 03-18-2026, 10:56 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
You got good advice above. To check for correct fluid level, park on a level surface, engine warmed up & idling, trans in neutral (actually, Park is OK too). Otherwise you are just guessing.
- Mike -
RIP El Jay
Old 03-19-2026, 03:20 PM   #13
MARKDTN
Likely low on fluid. Depending on pan could be 4-8 qts. If you can't see any on the stick on level ground and cold you don't have enough yet. I'd think at least 5 if not 6 qts.
How did the old fluid look? If I am looking at a filter in a transmission, I'm going to change it except in some very rare set of circumstances.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 03-19-2026, 05:56 PM   #14
68Gold/white
Drop the pan and make sure the filter is properly attached to the trans.
Something happened there, theres no other answer...
68Gold/white is offline   Reply With Quote
Old 03-19-2026, 09:12 PM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
The other answer is that it is low on fluid. There is going to be more than 4 QTs of fluid that comes out. It will likely take 9-10 QTs. Remember, fluid drains out of the trans back into the pan when the pump is not turning. Just because the pan only holds 4 QTs of fluid does not mean that that is all that is in the trans.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-19-2026, 09:20 PM   #16
70STOVEBOLT
On another note, Type F will not hurt the trans, it will cause firmer shifts. The issue is, you didn’t drain the torque converter, so if you had dexron in it before they are now mixed, AND, you now have old dexron mixed with new Type F, which kind of defeats the purpose of changing the fluid. The torque converter holds a few QTs of fluid. I would start it up on level ground let it warm up and add fluid until you see it at the full mark on the dipstick, I think you will find it cures your issue.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-19-2026, 09:35 PM   #17
Rust_never_sleeps
Does Dexron mix with Type F ?
Old 03-19-2026, 10:14 PM   #18
HeavyHauler
It has always been Type F that I have used and only Type F.
Old 03-19-2026, 10:19 PM   #19
HeavyHauler
I changed the filter and fluid using type F approximately 6 months ago. I am the one who probably caused the leak around my pan due to installing a rubber trans pan seal that never did seal very well and or my pan not being flat as I didn't check that.
I will double check the fluid this weekend with it running. I will need to find a good cork gasket instead.
Old 03-19-2026, 10:20 PM   #20
57taskforce
All about them K’s
57taskforce's Avatar
Dex 6 won’t hurt it. All this anti synthetic bs is amusing. Dex 6 is so far superior in every way to dex 3 and its reverse compatible meaning when the converter is still full of 3 you can safely run 6 on fluid and filter change. I run it in all my old automatics. It’s far more resistant to heat, the viscosity is more consistent, and it doesn’t foam near as much as 3. Sorry had to vent lol, I see these kinds of posts on some of the other boards I’m on and it drives me nuts how some of these opinions and understandings are skewed.
Tyler
57taskforce is online now   Reply With Quote
Old 03-20-2026, 08:29 AM   #21
72c20customcamper
72c20customcamper's Avatar
When I changed out the converter to a 2400 stall (th400) the instructions said it would void the warranty if synthetic was used . Only type F and Dextron III were acceptable. Converter was built for me by Yank.
Not saying you’re incorrect just my experience.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-20-2026, 10:14 AM   #22
SCOTI
SCOTI's Avatar
There are similar disclaimers for not allowing synthetic rear-end lubes as well as there's apparently 'too much' slippage on clutch material causing more harm than reducing temps so fluid is based on the differential unit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-20-2026, 11:42 AM   #23
57taskforce
All about them K’s
I run it in an original factory built (minus fluid and filter change) 700R4 in my IROC-Z, The th400 in my square body and the 4l80E which is also still a factory build in my K2500 HD. All originally spec’d for Dex2 and 3. They run cooler and the fluid says cleaner. I’ve got 100,000+ miles collectively on these with 6 and not a single negative thing to report, And I would if there was issues. It dropped the average towing temps in my K2500 by close to 10*.
I understand the warranty concerns for sure, and don’t blame you for not voiding that for what it’s worth.
Tyler
Old 03-21-2026, 04:48 PM   #24
70STOVEBOLT
Shouldn’t cause any issues, but I wouldn’t do it deliberately and only short term.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-21-2026, 05:34 PM   #25
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
B&M Trick Shift was about the same as Type F except it was dyed blue. I ran it for years in my hot rods after putting in shift kits. Don't know if it is still blue; it's been awhile.
~Steven
Simi Valley, CA
